Cheveron Delo 400 LE - Chevy and GMC Duramax Diesel Forum
 2Likes
post #1 of 67 (permalink) Old 03-12-2013, 12:15 PM Thread Starter
02Duramaxdually's Avatar
Is this oil any good?
2008 Chevy 2500HD CCLB LMM Duramax
Edge Insight CTS with Pyro
Allison Deep Trans Pan
B&W Goosneck Hitch & Airbags
285/75/16's
20% Tint all around with 40% Full Windshield
All stock for now, an staying that way, all emissions equipment still in tact.
155k an rollin
02Duramaxdually is offline
post #2 of 67 (permalink) Old 03-12-2013, 07:48 PM
mrmanners's Avatar
There are hundreds if not thousands of threads about oil here on DF. Delo and Rotella have been around a long time and are tried and true. Every has an opinion on what is "best". For me its synthetics from AMSOIL. For the next guy it might be Schaeffers or Mobil1. My recommendation is do some searching around on here and do some fact finding. Then try out what you think is best from that and see how things go.
If I can answer any questions about AMSOIL synthetics, please let me know.
mrmanners is offline
post #3 of 67 (permalink) Old 03-12-2013, 07:51 PM
e46_330i's Avatar
I use Delvac. Used Rotella in my motorcycle with no issues. Heard Rotella makes the duramax engine a little noisy on a few occasions. I use Mobil products in all my vehicles except BMW's (BMW oil only). Even my 270k miles Accord. Mobil conventional 5w-30. After 5000 miles black stone said it looks perfect.
LLY CCSB SLT 4x4
*EFI DSP5 By: PPEI *DE Downpipe & 5" Dump *ARP Studded *Pro-Fab Deleted *Custom Re-Routed *Alligator FPRV Plugged *DHD Braced & MA Sleeved *20x12 -44's *305/55/20 Terra Graps *LBZ MP, Intake & FPR *Kleinn Horns & On-Board Air *Paramount Restyling Grill hiding a 30" LunatecLED light bar *MA Pump Rub & M1 5w-30 *All-On Mod *PPE Boost & Pyro *Edge CTS W/Reverse Cam
Willie @ Synthetic Motorsports
Kory @ PPEI
Eric @ Merchant Automotive
Jason @ Alligator Performance
e46_330i is offline
post #4 of 67 (permalink) Old 03-15-2013, 05:26 PM
IDAMAX's Avatar
Delo is a great oil. I use it in all of my diesel engines. I have also used Mobil Delvac 1300 in this truck a few times, But always seem to go back to Delo.
2006 LBZ, Black CCSB LT
EFILive V2, Tuned by Rob, Edge CTS Insight, Titan 52 gal. Tank, AirDog Lift Pump, Nicktane Fuel Filter, S&B Intake, Diamond Eye 4" Turbo Back, EGR Blocked, PCV Reroute, Trans Go Jr. w/ Deep Trans Pan, Fuel Mavericks 18x9, 285/65R18 Toyo A/T2's, Rite Air Bags, B&W Hitches. 300K miles.
IDAMAX is offline
post #5 of 67 (permalink) Old 03-15-2013, 07:46 PM
DuramaxForum Guru
HD Dmax Machine's Avatar
YES! Oil brands are all personal preference.
HD Dmax Machine is offline
post #6 of 67 (permalink) Old 03-15-2013, 08:46 PM
I agree, Delo is a great oil.
As I understand it, Delo was developed as a marine diesel oil back around the beginning of World War II or thereabouts. The story goes that, at the time, submarine engines would require frequent overhauls due to the ineffective oils then available. The old Standard Oil Company of California formulated Delo to address that very serious problem.
By the way, anybody ever wonder what Delo stands for? Diesel Engine Lubricating Oil.
AlisoBob likes this.
Stock 2008 Chevy 2500HD, LMM w/Allison 6-speed auto transmission, short bed 4x4 w/crew cab and LTZ trim
74,000+ miles
Pullrite Superglide 16K 5th-wheel hitch w/3" lift kit
Nicktane OEM adapter w/Donaldson fuel filter
Planned mods:
1) Banks Speedbrake?
2) EGT gauge
I need all the I can get!
Rade is offline
post #7 of 67 (permalink) Old 03-15-2013, 09:10 PM
rms
rms's Avatar
I'm hoping it's good as well. There's a case of it waiting in my garage.
It's been Rotella for most of the time - this 3 gallon batch was on sale for $29.99 at Costco.
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/70/17 Michelin AT's on H2's - 8' Bedslide
Amp Steps - short KYB's - Fumoto
The Arizona Diesel Club
rms is offline
post #8 of 67 (permalink) Old 03-15-2013, 09:41 PM
willmonte72's Avatar
x3, oil is mostly preference. but if your looking to venture, delo is neat because its cheap, but it also depends on your driving habits, style, mileage, and what your truck responds to. for example, if you drive a ton, or lay on the throttle like some of us do, i would highly recommend a synthetic. if you use your truck for nothing special and are consistant on maintenance delo or rotella would be just fine.
2002 crew cab LB7/allison 1000 sleeper in progress
S475 over billet IHI, 45% exergy injectors, stock CP3 (trying to save the rods) Studs, y-bridge, built trans, t case, traction bars, fass 150 w/sump, tuned by Accel Diesel in Henderson Co. and bunch of other small goodies.
willmonte72 is offline
post #9 of 67 (permalink) Old 03-15-2013, 09:42 PM
SoCal06DMAX's Avatar
not sure how it is for our trucks but i run it in the trans on my 4 stroke dirtbike and so far so good
2006 2500HD Chevy 4X4 LBZ White CC/SB
6" Pro Comp lift on 325/65/18 Toyo Open Country AT's,Moto metal wheels, Moog Pitman/Idler & Pivot, Rough Country sleeves
AMP Reasearch Steps, Tow mirrors, Xentec HID's 5k lows & fogs, PCV Reroute, Transgo Jr, pump rub mod by Mike L@ Inglewood Trans, fumoto valve, Diamond Eye 4" TB Exhaust
http://madjacksynthetics.com/index.php
http://www.gotshocker.com/home.php
SHEET METAL WORKERS LOCAL 105
SoCal06DMAX is offline
post #10 of 67 (permalink) Old 03-15-2013, 09:57 PM
Dboonetx's Avatar
I agree that it made mine run quieter than rotela. And we use rotela in our tractors at home and all our excavators at work. But everyone has thier own opinions and every engine is different
2004 Chevy DRW 4X4 crew cab LB7, Nicktane with Cat filter, Silverline 5" exhaust straight pipe dumped with 6" tip, ported turbo horn, PPE Boost Valve, S&B intake, Ranch hand bumper on the front and custom hauler bed on the back with 108 gallon transfer tank, Edge CTS2, EFI live by Kory, FASS sittin on Ultra phantom's
DRW CLUB MEMBER #118
"I'd rather be a fence post in Texas than the king of Tennessee" - Chris Wall
Dboonetx is offline
