Fuel Additive??? - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 09-03-2009, 01:13 PM Thread Starter
Fuel Additive???
Hello all. So I am in the process of ordering a bunch of Amsoil stuff , but in the meantime was wondering about the Kleenflo everyone is talking about. I have seen it in our local town. But the Stanadyne is no where to be found here. As for the Kleen flo which ones does a guy get to use while waiting for the AMSOIL?? Injector Clean and conditioner?? They list the conditioner on their winter tab on the site. They have:
Diesel Fuel Anti-gel with Conditioner:
Low Sulphur Fuel Conditioner (Anti-gel) helps restore lost lubrication from the use of low sulphur diesel fuels. Lubricates fuel injectors and pump. Prevents freezing and icing of fuel lines and filters. Prevents gelling of fuel down to -45C. Methyl hydrate free. Reduces and maintains low exhaust emissions.
Diesel Fuel Conditioner:
A proprietary formula designed for diesel fuel. Eliminates varnish and sludge. Reduces corrosion. Prevents stalling and frozen fuel lines. Retards wax formation. Contains Anti-gel properties.
Diesel Fuel Conditioner (Low Sulphur):
Low Sulphur Fuel Conditioner helps restore lost lubrication from the use of low sulphur diesel fuels. Prevents freezing and icing of fuel lines and filters. Methyl hydrate free. Reduces and maintains low exhaust emissions.
Diesel Lubricant:
All season diesel lubricant (low sulphur formula) provides superior lubricity and anti-wear protection for diesel engines. Lowers the pour point of diesel fuel and helps disperse water. Cleans and lubricates the entire fuel system while decreasing engine smoke and increasing power. Treats up to 3000 litres. Alcohol free.
So which ones are the ones to get for my 2001 LB7?? Thanks guys & gals!!
Bluearc
bluearc74 is offline
post #2 of 5 (permalink) Old 09-03-2009, 02:55 PM
BUBBA3M's Avatar
Welcome to the DF!! Do a search on this as there are a ton of threads on which additives are best. I use the AMSOIL Diesel Conditioner myself.
2013 LML, 6 spd Ally, CC/SB, Bone Stock
2015 Copper Canyon 33ft 5th wheel
BUBBA3M is offline
post #3 of 5 (permalink) Old 09-03-2009, 03:25 PM
j4nash's Avatar
Diesel Lubricant:
Bluearc
Get yourself some Amsoil Diesel Concentrate and while you are waiting for your order to arrive i would just got to wal-mart or a auto parts store and pick up a bottle of Diesel Kleen + Cetane Boost
2007 GMC 3500 LBZ CC/LB SLE
Edge Insight Monitor CTS, BD Exhaust Manifold, 4" Corsa Exhaust, EFI Live w/ DSP2 http://www.atptrucks.com/ . Banks 3" Boost Tube
Mag-Hytec Rear differential cover, Bypass Coolant Filter
j4nash is offline
post #4 of 5 (permalink) Old 09-03-2009, 03:36 PM
Banned
I always vote stanadyne performance formula. Where do yuo live, I bet you can find it close, and if you have to order it you can.
MMLMM is offline
post #5 of 5 (permalink) Old 09-04-2009, 03:40 PM
Just make sure that you get one that is alcohol free, and has the most lubrication available, the AMSOIL will be there before you know it!
bigdaddydiesel is offline
