Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > Alternative Fuels - Diesel - Additives - Lubricants
Alternative Fuels - Diesel - Additives - Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Old 11-07-2009, 02:04 AM   eBay Motors   #31 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Originally Posted by saskboy View Post
How come nobody here runs 0w40 all year round? All my vehicles get esso xd3 0w40, its better cold flow than any other oil and protects the same as 15w40 when hot. When I used to work in lloydminster one company ran that stuff year round in every piece of heavy equipment they owned, crawlers, scapers, track hoes, dump trucks, half tons, and so on.
Ummmm never saw it in the US...must be a canadian thing.
Old 11-07-2009, 05:29 PM   eBay Motors   #32 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
Just to clarify one thing, our CJ-4 5w-40 (DEO) Diesel Oil CAN be run in higher temp climates. But the main purpose for it is for better cold flow characteristics in the colder climates. but like stated already, they are the same when up to normal operating temp.
As for the op's original question, I think that the biggest difference between conventional and synthetic oil is the wear protection and the fact that synthetic oils do not break down as easily as conventional oils. You see, as conventional oils break down the larger molecules of the oil get "Stuck" to the sides of the oil flow galleys in the engines and throughout the oiling system. As they get "Stuck" they overheat and get burn against whatever part of the engien they are touching. As they do this they form the dreaded sludge that you see when you open the engines up. Now, because the sludge is there in the first place, the oil cannot flow throughout the engine as well and this all but eliminates the oil's ability to dissipate the engine heat as well as it should. No matter how often you change your conventional oil, that sludge build up stays behind when you drain the oil, and continues to build up over time. This slowly reduces the efficiency of the engine overall. but it also increases the particle load of the oil almost immediately upon installing new oil so that it is broken down even faster than in a fresh engine.
AMSOIL Synthetic oils have built in heavy duty detergents and dispersant additives and high TBN (10.4) formulation that effectively neutralizes acids and controls soot thickening from the EGR and blow-by to protect against corrosion, cylinder bore polishing, and varnish or sludge deposits better than any conventional oil on the market. Period.
The truth? No conventional oil, no matter how often you change it, will give you the same high quality results and efficiency as AMSOIL, for the long haul beyond the normal 500K life expectancy of these trucks. If they were built to last for 500K miles with conventional oils, then they can go a lot farther with AMSOIL!!!
I have no doubt. As do every other customer of AMSOIL that has ever ran their products for any length of time.
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
