Alternative Fuels - Diesel - Additives - LubricantsDiscussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Just wanted to let everyone know what kind of numbers I'm getting with Amsoil from front to back in my truck.
I have changed over all my fluids in my truck to Amsoil here is the list of fluids I switched over to:
Engine oil: SAE 15W-40 Heavy-Duty Diesel and Marine Motor Oil
Front and rear differential: Severe Gear 75W-90
Trans: Torque-DriveŽ Synthetic Automatic Transmission Fluid
Brake fluid: Series 500 High-Performance DOT 3 Brake Fluid
Power Steering Fluid: Synthetic Universal Power Steering Fluid
Fuel additives: Diesel Concentrate and Cetane Boost
First good highway trip with no load to test out the mileages since changing everything over to Amsoil. So with a stock LBZ we made 20.2mpg hand calculated going 80mph with two stops and some idling time.
__________________ 2007 GMC 3500 LBZ CC/LB SLE
Mag-Hytec Rear differential cover
AMSOIL Front to Back
__________________ Pickup: 2002 Chevrolet 2500HD Duramax/Allison Reg. Cab with
Royal Utility bed and racks
Intake: Stock with KN Filter
Transmission: Stock
Mileage: 151,000 No Rust
AWSOME!!! Can I ask what you were getting before (under exact same conditions?)?
__________________ '05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
what!!!!! thats crazy! especially the fact that you were cruising 80!!!!
cant wait to see if my amsoil change will make a difference for me!
__________________ 06' LBZ 2500HD CC shorty
BD 4" turbo back exhaust dual 5" tip (straight piped)
6" tuff country lift
LT315/75R16 BFG all terrains
Cognito HD tie rods
16x8 eagle alloy series 185
all around tint
line-x
resonator plugged
Amsoil from Chris (bigdaddydiesel)
^^^ X2 ......?
Transmission: Stock
that is really good mileage... makes me wonter what i should put in mine.
__________________ 09 white on black CC/SB LTZ loaded.
RPB grill, 6k HIDs hi/low and fogs, pyro/boost gauges, 7-9" cognito, air bags w/compressor, train horns, 20" rockstars, 35" toyo MTs, 5% tint, AMP steps, DPF DELETE, 5" magnaflow w/ RPB tip all gone but the muffler, AFE intake, two JL 10's, all new interior speakers, PPE HOT, titan tank, bed liner, 10inch adjustable drop hitch, and more to come!
Give Big Daddy or Mr. Manners a shout about it- they can work you out a quote and answer any questions you may have about Amsoil...
I'm using the fuel additive but is the cetane boost worth the extra money?
__________________ 05 Silverado Ext.Cab Short Bed w/ Turbo Back Exhaust,debadged,Camoclad exterior(advantage max4 hd),black grille,steps,and bumpers,blocked egr and fingerstick,Banks intake,lbz mouthpiece,plugged resonator,Edge Juice w/ attitude,Clifford 2-way remote start,7" cognito lift from Nick at Nor-cal Truck w/ 35" pro comp xtreme mud terrains on blacked out 20" kmc monsters
