Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > Alternative Fuels - Diesel - Additives - Lubricants
Alternative Fuels - Diesel - Additives - Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Old 10-27-2009, 06:22 PM   eBay Motors   #1 (permalink)
Dura2thaMax
Dura2thaMax's Avatar
Shell Rotella T 15w-40 Dino
Is this oil good for South Dakota winters? sometimes the high is 0. but most of the time 15-30 degrees?
Thanks
07 Sierra 2500HD CC SB Classic. Loaded
LBZ
4" Rancho Susp. Lift
K&N Intake
Edge Juice w/Attitude
Dura2thaMax is offline   Reply With Quote
Old 10-27-2009, 06:26 PM   eBay Motors   #2 (permalink)
Jonsey181
Jonsey181's Avatar
I would say yes, I have used nothing but Rotella we use it in our semis also which they are all over and run perfectly fine in below zero weather
Eric: 2005 GMC 2500HD LLY
Jonsey181 is offline   Reply With Quote
Old 10-27-2009, 06:26 PM   eBay Motors   #3 (permalink)
lutzjk913
lutzjk913's Avatar
i ran in our old international tow trucks all winter long. my uncle runs in his cummins and i run it in mine also. my family swears by it.
Joe, 22
2008 CC LB LT2 DURAMAX LMM
MBRP 4" TB back(NO CAT, NO DPF, NO MUFF), Quad II on 135HP, Tie rod sleeves , 15% tint, 5" factory running boards, gm vent shades and bug deflector
next on the list
transgo jr, EGR blocker, gauges, spray in bedliner, 285 BFG A/T, leveling kit
special thanks to
nate @ www.performancetruckproducts.com
tyler@ www.meyerperformance.com
lutzjk913 is offline   Reply With Quote
Old 10-27-2009, 06:27 PM   eBay Motors   #4 (permalink)
Jonsey181
Jonsey181's Avatar
and we drive in north dakota.... which is colder than south dakota
Old 10-27-2009, 06:38 PM   eBay Motors   #5 (permalink)
lutzjk913
lutzjk913's Avatar
it was -30 and below for over a week.
Joe, 22
next on the list
special thanks to
Old 10-27-2009, 06:40 PM   eBay Motors   #6 (permalink)
mijdirtyjeep
mijdirtyjeep's Avatar
just don't crap your pants when you fired her up after it has been sitting outside in -15deg weather for 2 days and the oil pressure pegs at 120psi
Jim
4" Magnaflow Exhaust
Modified factory air box
Ported Turbo Horn
EFI LIVE V2
mijdirtyjeep is offline   Reply With Quote
Old 10-27-2009, 06:56 PM   eBay Motors   #7 (permalink)
side2000
side2000's Avatar
if you're really sweatin it you could try runnin the synth 5w-40. let it warm up real good before ya rip on it though or ya might burn some. with a low mile '07 it would prob suit ya nicely.
'02 2500 VP'd 24v cummins; HO w/ an SO pump; nv5600 w/ beast single disc, DDP 110's, stock turbo, 285's. ISSPRO: pyro, boost, FP. FASS 150, 5" straight pipe, edge drag comp.
side2000 is offline   Reply With Quote
Old 10-27-2009, 07:04 PM   eBay Motors   #8 (permalink)
Dura2thaMax
This will be the first time I change the oil in the truck. This is my first DMax. The napa guy was trying to sell me Royal Purple I promptly said NO. So many options. Thought about going synthetic, but Im not into the Amsoil.
LBZ
K&N Intake
Old 10-27-2009, 07:08 PM   eBay Motors   #9 (permalink)
Jonsey181
Jonsey181's Avatar
well I as a consumer would say you would be best off with Rotella T it is widely known and usee, alot of people like it, I usually just go by if its good enough for expensive equipment (semis & farm equipment) its good enough for my truck
Old 10-27-2009, 07:28 PM   eBay Motors   #10 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
That is a good conventional oil. It will work. If you want to go Synthetic, there are others other than Amsoil. If you choose to go with it, Mobile 1 or Shaeffers would be my next choices.
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
