Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > Alternative Fuels - Diesel - Additives - Lubricants
Alternative Fuels - Diesel - Additives - Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Old 10-30-2009, 05:27 AM   eBay Motors   #1 (permalink)
#25ashley
Rotella Synthetic
Went to change oil (from the previous owner) Wanting to run Rotella Synthetic. Truck calls for 15-40 conventional oil. Only thing I could find,was Rotella 5-40 synthetic. My question is, Is that exceptable? Do they make a 15-40 synthetic? Live in the mid atlantic region,where it does not get too cold nor too hot. I'm thinking the 5-40 would be ok. What is the opinion here?. Thanks for the help
2006 Silverado 2500HD AFE air intake. Other than that Bone Stock
#25ashley is offline   Reply With Quote
Old 10-30-2009, 05:50 AM   eBay Motors   #2 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
5w40 will be fine. the 5 is just for colder weather. I havent seen any sythetic that wasnt 5w40. That is all i have run in mine....-50F to 90F in the interior of alaska.
Old 10-30-2009, 07:26 AM   eBay Motors   #3 (permalink)
Dura2thaMax
Dura2thaMax's Avatar
I have been debating on that too as I live in South Dakota. I can get well below zero here and over 100 in the summer.
07 Sierra 2500HD CC SB Classic. Loaded
LBZ
4" Rancho Susp. Lift
K&N Intake
Edge Juice w/Attitude
Dura2thaMax is offline   Reply With Quote
Old 10-30-2009, 07:31 AM   eBay Motors   #4 (permalink)
#25ashley
So even in the dead of summer when it get's to be in the high 90's and pulling a 30' camper. I should be fine?
Old 10-30-2009, 07:37 AM   eBay Motors   #5 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
yes you will be fine. the 40 weight is for the hot.
Old 10-31-2009, 12:14 AM   eBay Motors   #6 (permalink)
GMC4Me
GMC4Me's Avatar
AMSOIL makes a 15w40 full synthetic diesel oil, which I use. You might want to think about staying with 15w40.
Your owner’s manual says 15w40 because your oil pump is designed to work optimally (pressure and volume) with this viscosity of oil within a specific temperature range. Will running 5w40 hurt anything? Probably not, but GM did not pull this requirement out of their ear for no reason.
IMO, unless you are in serious cold country I would stick with a 15w40 for all seasons.
2008 GMC 3500 Crew Cab Long Bed 6x6 - Stock
AMSOIL Everything (except Antifreeze)
Reese "Tow Beast" Class V Receiver
Rhino Bed Liner (Not recomended)
AMSOIL Remote Bypass with Precharger and FilterMag
PCV Reroute
Mag-Hytec Differential Cover and Deep Transmisson Pan
14.8 Calculated Average MPG (No Load)
GMC4Me is offline   Reply With Quote
Old 10-31-2009, 01:19 AM   eBay Motors   #7 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Depending on where you live and the temps you see will depend on the weight of oil that you need to run. the only difference between 5w40 and 15w40 is you can use the 5w40 in colder weather. They are both rated for the same hot weather.
Old 10-31-2009, 01:31 AM   eBay Motors   #8 (permalink)
kman2468
kman2468's Avatar
sorry but i have to ask this... it reaches 90 in alaska??
04.5 LLY Duramax Diesel CC/LB D/A
5" exhaustwith 5-6" dual wall black tip
EFI tuned by MMLMM
8000k fogs and low beams
smoked recon cab lights
www.discounttiredirect.com
kman2468 is offline   Reply With Quote
Old 10-31-2009, 01:34 AM   eBay Motors   #9 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Yes it does in fairbanks...the interior.
Old 10-31-2009, 01:36 AM   eBay Motors   #10 (permalink)
kman2468
kman2468's Avatar
well i learn something new everyday haha
i thought it was mostly always cold there
EFI tuned by MMLMM
