Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > Alternative Fuels - Diesel - Additives - Lubricants
Alternative Fuels - Diesel - Additives - Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Old 11-01-2009, 01:17 PM   eBay Motors   #1 (permalink)
biketopia
biketopia's Avatar
T-Case Fluid Is Blue???
I did an oil change the other night and took the opportunity to check out the diffs and T-case for the first time since I got the truck. Every thing seems normal and very clean except for one thing. The T-case fluid is blue?? It seems to be some sort of oil, just don't know what. The only other blue oil I know of is John Deere, they dye the 15w40 they use for hyd fluid in there new back back hoes. Any ideas?
03 2500HD Crew Cab Long Bed Dark Green and Bone Stock...For now
biketopia is offline   Reply With Quote
Old 11-01-2009, 01:20 PM   eBay Motors   #2 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
someone put autotrac II fluid in your transfer case. By GM it is supposed to be tranny fluid. The Autotrac fluid wont hurt, but its not what is recommended
Old 11-01-2009, 01:20 PM   eBay Motors   #3 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
The only thing I can see being blue is autotrack fluid.. I know motorcraft rear end addative is blue..
drain and refill with 5-30 motor oil.
Old 11-01-2009, 05:59 PM   eBay Motors   #4 (permalink)
biketopia
biketopia's Avatar
why 5w30 over ATF?
Old 11-01-2009, 06:02 PM   eBay Motors   #5 (permalink)
Hondarider552
Originally Posted by biketopia View Post
why 5w30 over ATF?
ATF will evaporate when motor oil will not. doesnt harm your tcase, Mike L preaches to run it and my 4wd engages/disengages smoother than it ever did.
Old 11-01-2009, 07:53 PM   eBay Motors   #6 (permalink)
K9Duramax
K9Duramax's Avatar
and don't forget that the AUTOtrak is expensive as all get out!!!!!!!!!! Just as well put liquid gold in there... lol
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is offline   Reply With Quote
Old 11-02-2009, 12:49 AM   eBay Motors   #7 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
yeah the 5w30 write-up said to overfill with 3 quarts through the speed sensor. I did this. I havent had any problems yet.
Old 11-04-2009, 11:07 AM   eBay Motors   #8 (permalink)
DeereMan
DeereMan's Avatar
I seem to remember reading an article about this. Let me see if I can find it.
2007 Silverado Classic 2500HD LBZ
EC,SB, Allison 1000 6 speed
265's on 16x8" Eagle Alloy wheels
Blocked EGR
PCV Rerouted
BD LH Exhaust Manifold
Diamond Eye Turbo Downpipe
MBRP 4" Front Cat Delete pipe
Banks 4" Monster Exhaust
Banks 3" Intercooler Tube
50Gal Inbed Auxilary Tank
DeereMan is offline   Reply With Quote
Old 11-04-2009, 11:10 AM   eBay Motors   #9 (permalink)
RedBowTies88
RedBowTies88's Avatar
Originally Posted by DeereMan View Post
This has been a widely spread rumor for a while now but no one has yet come up with any proof that the ATF is actually evaporating. The suspision is that it is more of a maintenance (or lack of maintenance) issue. Fill the transfer case with synthetic ATF if you have any doubt.
when i changed to motor oil i had a tiny bit over 1qt of atf in there....
its proven 5-30 is the way to go...all the big boys racers and pullers use it
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 11-04-2009, 11:35 AM   eBay Motors   #10 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
I agree, I have only heard good things about 5w-30 syn in the transfer case. There are many tranny builders nationwide that are swearing by 5w-30 syn in there...
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
