Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > Alternative Fuels - Diesel - Additives - Lubricants
Alternative Fuels - Diesel - Additives - Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Old 11-03-2009, 07:06 AM   eBay Motors   #1 (permalink)
DuraLMM
What to lubricate in the driveline?
Is there any grease or spray lubricants that need applied external to the driveline? I seen a rubber boot around the shaft that comes out of the back of the transfere case that has a small weep hole in the bottom of it. Does something need sprayed up in there?
DuraLMM is offline   Reply With Quote
Old 11-03-2009, 07:46 AM   eBay Motors   #2 (permalink)
scottdomine
scottdomine's Avatar
No! My truck has no grease zerks on the driveline at all. However, my old 1500 had them on the both u-joints!
2002 Silverado 2500HD LBZ FE9 Ext Cab 4x4 LT, 133k miles (08/12/09), American Racing Chrome Nitro's, Goodyear Wrangler MT/R 285/75R16, Resonator plugged, B&W Turnover ball, Amsoil Synthetics throughout truck, Bilstein 5100 shocks, Westin Chrome Bars, Adrian Double Lid Box, Line-X sprayed liner, PPE Economy Tuner Running Level 2(Thanks Husker Diesel)! 4" MBRP Turbo Back w/ chrome tip (Thanks again to Husker Diesel), Pillar Mounted Autometer Cobalt Boost and Pyro gauges
"Contact All in One Logistics or http://www.syntheticmotorsports.org for all your AMSOIL needs!"
scottdomine is offline   Reply With Quote
Old 11-03-2009, 12:41 PM   eBay Motors   #3 (permalink)
Dirtbikindad393
Your #1 Source For Amsoil
Dirtbikindad393's Avatar
No there are no external areas needing to be greased or sprayed.
MadJack Racing & Synthetics
MadJack Racing is Your #1 Source For Amsoil And Discount Diesel Parts
Credit Cards Accepted
Dirtbikindad393 is offline   Reply With Quote
Old 11-03-2009, 12:47 PM   eBay Motors   #4 (permalink)
scottdomine
Call me "old school" but I like to be able to grease everything. Guess no need for it anymore. I have, however, removed my driveshaft and greased the output shaft on the trans case real good!
Old 11-03-2009, 01:00 PM   eBay Motors   #5 (permalink)
seth999
Duramax Forum Moderator
seth999's Avatar
I just grease wherever there are zerks and go with it
DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
seth999 is offline   Reply With Quote
Old 11-03-2009, 01:51 PM   eBay Motors   #6 (permalink)
lostscout
lostscout's Avatar
Greasing
myself also -grease is cheap parts aren't sealed steering components pi$$ me off
lostscout--06 Sierra LBZ D/A (named Ironhorse) Pewter all stock owned since June09
**AMSOIL thanx to MRMANNERS**
lostscout is offline   Reply With Quote
