Originally Posted by saskboy Ahhhhhhh.....What! The only way you can drain a femco plug is with the hose adapter, you can get straight or 90 degree drain hoses for them so I dont see how you cant control where the oil goes. The Fumoto ones with the valve handle deal kinda suck because anyone could just walk up to your truck and dump your oil on you. The big valve is easier to get knocked off. |
My appologies not knowing how the Femco works I did not know that.
As far as someone opening my Fumoto..........I have never had anybody walk up to my truck climb on the ground slide under the truck and then try and open my Fumoto valve with a safety clip on it. If I caught them
they would NEVER use their nuts again because I would have already cut them off and thrown them into the bushes for the mice to eat while I am looking down on them
but fair point none the less.
Nobody would even be able to open it a valve with a safety clip on it unless they had a pair of channellocks and 10 minutes for someone that doesn't know how to take the clip off or spring clip pliers and try take off the clip. Its an art to take the safety clip off and put back on these valves properly.
