Alternative Fuels - Diesel - Additives - LubricantsDiscussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
As a dealer of fluids I can't recommend it because its not what the mfg spec'd. Ask me what I run though and I will tell you. I run 5W-30 in my t-case it got much quieter. I have had no problems with it in my personal use of it. I didn't overfill using 3 qts though. I only did 2 qts because I am old school and overfilling scares me still. I figure if I am under the truck doing maint I can just as easy take out the fill plug and check the fluid level in my t-case.
MadJack Racing & Synthetics MadJack Racing is Your #1 Source For Amsoil And Discount Diesel Parts
Credit Cards Accepted
thanks man...i guess ill give it a shot
i would assume you used full synthetic?
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Yes I did. It is all I use in anything and everything I own but you know why too.
of course i do lol...well thanks again for that input ill probably be doing it tonight. if i notice a big change i may just start a thread stating my success.
LLY Cc/sb 4x4 RED
3 qurats of fully synthetic 5w30 motor oil thru the speed sensor hole.
Not a reason not to do it on the planet. Manuf. spec will be just fine, but this is considered a mod i guess. A cheap one that can be beneficial to the owner of the truck.
OK so now i want to change mine, can i use semi synthic 5w 30 or ATF or what? Also why 3 qts and not just 2?
__________________ 06 crew short bed 4x4 LT3 LBZ
Magnaflow 5in TB Exhaust-AFE Stage 2 Resonator Plugged
Painted Door Handles-6000k HIDS-Double Din DVD- 3-12in Kicker Solobarics with 1800watts RMS
Autometer Phantom Gauges
PPE with transgo
Cst 9-11 lift set @ 10" W/bilstein 7100's
37" Toyo MT's on 22" trax8 wheels
Sold: 04.5 LLY LT Lifted on 37's
Big thanks to Mike @ Dmaxstore
For all you Wheel and Tire needs shop http://www.discounttiredirect.com
gotcha...thanks mike.....is the speed sensor hole obvious? if not can you tell me where it is/ how to remove speed sensor?
Its on the top of the T-Case its a black plactic do dad that has a wire going to it. Its a large size you could use a cresent wrench but don't strip the plastic nut base it has. Maybe Mike knows what size wrench it is.
