Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > Alternative Fuels - Diesel - Additives - Lubricants
Alternative Fuels - Diesel - Additives - Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Old 08-24-2009, 05:51 PM   eBay Motors   #21 (permalink)
RedBowTies88
RedBowTies88's Avatar
gotcha well if thats all it should not be too hard
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 08-24-2009, 05:57 PM   eBay Motors   #22 (permalink)
mijdirtyjeep
mijdirtyjeep's Avatar
I have the 3qts of 5w30 in mine as well. I removed the speed sensor with an adjustable wrench, and it was not that tight. Just lightly break it loose and then turn it out with your hand. Mine was in there I assume for around 180k and it came out just fine.
Jim
4" Magnaflow Exhaust
Modified factory air box
Ported Turbo Horn
EFI LIVE V2
mijdirtyjeep is offline   Reply With Quote
Old 08-24-2009, 05:59 PM   eBay Motors   #23 (permalink)
Nuclearzero1
Nuclearzero1's Avatar
Originally Posted by RedBowTies88 View Post
bringing this back up with a new question...though probably a dumb one i plan on using ATF for the case and not motor or gear oil. any reason why i should dex III or dex VI over one another? i dunno if the VI is thinner or anything....
Dex VI is fine to use as well it is replacing or probably going to replace Dex III so same properties but just recomended for newer vehicles. But I do agree with the guys as well with Using motor oil or even a higher gear weight. Its almost down to personal preference i think.. but what do i know
Nuclearzero1 is offline   Reply With Quote
Old 08-24-2009, 06:04 PM   eBay Motors   #24 (permalink)
GMC4Me
GMC4Me's Avatar
Excellent find 56Nomad. Thank you for posting the link. I would hazard a “guess” that the reason for the 5w30 recommendation from the author (vs. a 90wX) might have something to do with the capabilities of this specific transfer case’s oil pump. I use 4WDH a lot and I seem to lose about a ½ pint of ATF in 10K miles so I will try 5w30 at the next service interval.
Even though I am sure it hurts my mileage a bit, I changed out both differentials to Amsoil Severe Gear 75w-110 (instead of 75w-90) at 4K miles and so far the lube looks as clean as new. The rear differential’s stock stuff was already really nasty at 4K miles, probably from break-in heat.
2008 GMC 3500 Crew Cab Long Bed 6x6 - Stock
AMSOIL Everything (except Antifreeze)
Reese "Tow Beast" Class V Receiver
Rhino Bed Liner (Not recomended)
AMSOIL Remote Bypass with Precharger and FilterMag
PCV Reroute
Mag-Hytec Differential Cover and Deep Transmisson Pan
14.8 Calculated Average MPG (No Load)
GMC4Me is offline   Reply With Quote
Old 08-24-2009, 07:35 PM   eBay Motors   #25 (permalink)
mysupersportss
mysupersportss's Avatar
So how come 3qts motor oil and not 2?
06 crew short bed 4x4 LT3 LBZ
Magnaflow 5in TB Exhaust-AFE Stage 2 Resonator Plugged
Painted Door Handles-6000k HIDS-Double Din DVD- 3-12in Kicker Solobarics with 1800watts RMS
Autometer Phantom Gauges
PPE with transgo
Cst 9-11 lift set @ 10" W/bilstein 7100's
37" Toyo MT's on 22" trax8 wheels
Sold: 04.5 LLY LT Lifted on 37's
Big thanks to Mike @ Dmaxstore
For all you Wheel and Tire needs shop http://www.discounttiredirect.com
mysupersportss is offline   Reply With Quote
Old 08-24-2009, 07:54 PM   eBay Motors   #26 (permalink)
CHYKYNLIPS
One thing that came to mind when capacity was discussed is how is the fluid transfered in the transfer case? I know its apples and oranges, but for example, in an older lawnmower engine, there is no oil pump but a slinger type system and if the oil level is over filled, the oil cant be slung around in the engine if that part is over submersed. Does this apply at all to our transfer case?
07.5 LMM Chevy CCSB Z71
Edge Evo Race, Banks Ram Air,
MBRP 5" Exhaust W/DPF Delete
EGR Blocker Plate, PCV Reroute Mod
6" Fabtech, 18" Chrome Diamo 8 Karat
35"X12.50" Toyo Open Country M/T
Thanks to Tyler at MPF for all performance mods!
CHYKYNLIPS is offline   Reply With Quote
Old 08-25-2009, 03:57 AM   eBay Motors   #27 (permalink)
sparky660
THat is a good question. Does the transfer case have an oil pump or does it rely on the gears to sling it and carry it.
I am sitting on the fence with this 5W30 stuff as I live in Canada where the winters get really cold. I think I will air on the side of caution and go with the less viscous fluid Syntetic ATF)for cold weather flowability. My transfer case is super quiet with 170,000 kms so if it isn't broke don't fix it.
Are there any Canadian people reading this using 5W30???
2005 Crew Cab Regular Box 4wd. Bone stock for the time being.
sparky660 is offline   Reply With Quote
Old 08-25-2009, 05:42 PM   eBay Motors   #28 (permalink)
Redram99
I'm from Canada.
I put 5-30 syn in my transfer case. But will only be using it for the summers and will change back to ATF for the winter. -40 does is hard on things so I think I would be better off with ATF in the winter.
The syn motor oil allows my tcase to shift easier and operate quieter.
2002 Chevrolet 2500HD LT CC Short Box with 230,000 KMs. 4" lift, Pacbrake, Superchips tuner
Redram99 is offline   Reply With Quote
Old 08-25-2009, 05:45 PM   eBay Motors   #29 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
more is better in terms of the life of the tcase
Old 08-25-2009, 07:13 PM   eBay Motors   #30 (permalink)
mysupersportss
So if I decide to do atf should I do 3qts or just to spec and do the 2qts?
PPE with transgo
