Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > Alternative Fuels - Diesel - Additives - Lubricants
Alternative Fuels - Diesel - Additives - Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Old 11-04-2009, 02:06 PM   eBay Motors   #61 (permalink)
Buck
Buck's Avatar
In my personal experience the less you mess with stuff the longer it lasts. So i say fallow the manufactures specs for drain intervals and fluids used and be done with it.
or switch everything to amsoil and run it all forever as long as your monthly tests say its ok!
Vehicle 2008 Chevy Crew Cab Short Bed
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline   Reply With Quote
Old 11-04-2009, 04:27 PM   eBay Motors   #62 (permalink)
RedBowTies88
RedBowTies88's Avatar
wouldnt hurt to try it once buck....bet you feel a difference
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 11-10-2009, 08:09 PM   eBay Motors   #63 (permalink)
09darkdmaxx
09darkdmaxx's Avatar
so after reading all of this... can i run amsoil torque drive??? has anyone else? i have no prob getn some more oil but i have the other handy
-09 2500hd cc/sb
ppe intake mod with afe pro gaurd 7, turbo resonator block, pvc re-route...edge cs race, dpf delete, no muffler mbrp 4" turbo back,shim kit, egr blocker,diamondeye downpipe,transgo jr., deep pan,ready lift leveling kit, 285/75/16 pro comp xtreme a/t...and a new boss 8'2 power-v xt
in spring: airdog2, tie rod sleeves, cognito tie rod ends, suncoast stage3, afe bladerunner turbo inlet, snow performance stage1 water/meth, bd manifold!!!!
-08 2500hd reg/lb 6.0 (gasser)
flowmaster single cat-back exhast, airaid cold air intake, predator diablo tuner, 285/75/16 coopers, leveling lift
AlligatorPerformance.com/Amsoil syn/Powermaxperformance
09darkdmaxx is offline   Reply With Quote
Old 11-11-2009, 06:20 AM   eBay Motors   #64 (permalink)
RedBowTies88
you can but i would HIGHLY recommend 5-30 oil...made my t-case much smoother
LLY Cc/sb 4x4 RED
Old 11-11-2009, 06:35 AM   eBay Motors   #65 (permalink)
09darkdmaxx
k i will get some oil then
-09 2500hd cc/sb
