best 15w-40 oil and filter for dmax? - Page 21 - Chevy and GMC Duramax Diesel Forum
post #201 of 344 (permalink) Old 04-01-2011, 12:26 PM
KB3MMX's Avatar
Yes, it's CI-4 and CJ-4 rated, in addition to several other ratings. It will work Excellent in your 06 or a 08up truck.
Rotella T6 Info
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline
post #202 of 344 (permalink) Old 04-01-2011, 11:10 PM
doesnt the oil start thick and thin up when it gets warm??? so a 5/40 would be thickest at start @40 then thin up to 5 when warm, a 15/40 would be 40 at start then thin to 5. the higher the weight the thicker the oil hence gear oil being super thick and 75-90. am i not correct on this??
Draz is offline
post #203 of 344 (permalink) Old 04-02-2011, 06:29 AM
blackdeath's Avatar
yes but u cant associate the numbers like that,
The first number in the oil weight represents the oil's viscosity at 0 degrees F. The lower the first number in an oil's weight, the thinner it is at low temperatures. Oil that is thinner at cold temperatures is typically better suited for winter driving.
Second Number
The second number, the number after the W, represents oil's viscosity at 212 degrees F. The higher the number, the thicker the oil will stay at high temperatures. Thicker oil at high temperatures is better for summer driving.
blackdeath is offline
post #204 of 344 (permalink) Old 04-02-2011, 11:02 AM
theoretically i'm understanding it as I think we all have but in essence it is contradicting itself. so at start up its at 5w and at 212 degrees its 40w. in essence its thinner when its been sitting and cold and thicker at hot temps. just seems contradicting to me.
08 LMM 2500HD C/C 4wd Short Bed Diamond Eye 4" straight pipe turbo back Edge CTS Race EGR Blocked PCV Reroute Debadged HID/LED all around
Draz is offline
post #205 of 344 (permalink) Old 04-02-2011, 03:01 PM
KB3MMX's Avatar
Post
No.
Multi-Viscosity oil is rated in correlation to temps of operation with the cold viscosity first/Warm Viscosity second.
So, a 15W-40 is a 15Weight during cold operation(startup) and 40 Weight at "normal" operating temps.
That's why a 5W-40 is MUCH better for startup protection by reducing the time until oil gets to moving parts.Heyyaa
KB3MMX is offline
post #206 of 344 (permalink) Old 04-04-2011, 01:13 PM
BlackBetty06's Avatar
so really, you should be able to run 5w 40 all year round since 5w40 and 15w40 will act the same once warmed up. Correct??
DD: 2006 Duramax Diesel Black CCSB: 4" straight pipe: Big Dipper Trans: Banks Ram Air intake: ATP DSP5: BD Manifold: Air Dog II: resonator deleted: all on mod: B5+ every tank
491 HP/ 1018 TQ(Edge Evo Race LVL 7 numbers)
Work Truck: 2016 transit 250 Eco-boost
My First Truck: 1990 Chevy 1500 sport reg cab 4x2 5.SP Man with 4.3v6.
BlackBetty06 is offline
post #207 of 344 (permalink) Old 04-04-2011, 02:09 PM
KB3MMX's Avatar
Yes
KB3MMX is offline
post #208 of 344 (permalink) Old 04-04-2011, 02:20 PM
KB3MMX's Avatar
Post
Yes but what ties it all together, is what BlackDeath said, the unit of measurement is at a certain temp.
Viscosity measurement takes temperature into account.
Let me explain. A 5W rating at 0f is a 5weight oil however if you heat that exact rated oil to 212f, it will be much thinner and might be a 0w if tested at 212f.
Now, if a 40W oil that was rated at 212f was brought down to 0F, it might be actually a 60W if measured at that temperature.
The way oil companies can manipulate viscosity ranges in a Multi-vis oil is through the additive package, containing Viscosity Index Improvers, etc.
What also seperates oils is whether it's Synthetic or Conventional and that changesis the need for these viscosity improvers. A synthetic oil requires less of the additives because it's more stable than a conventional oil due to more uniform carbon chains.
KB3MMX is offline
post #209 of 344 (permalink) Old 05-28-2011, 08:13 AM
titch--'s Avatar
Just giving this thread alittle bump and going to ask my question here instead of starting a new one.
Anyways Im about to do a oil change and I already have a 5L jug of rotella t6 and I was wondering if I just get another rotella or get some 15x40. Is it possible to mix oil weight like 5x40 and 15x40 without screwing anything up?
Im the way of thinking that 5x40 was for winter and 15x40 was for summer but a few posts back tells me other wise.
cheers
titch-- is offline
post #210 of 344 (permalink) Old 05-28-2011, 08:46 AM
I'm That Guy...
TDFDiesel's Avatar
cheers
Any reason you use an "x" instead of a "w"?
Tony
Old Trucks: 3 - LLY, 1 - LMM
TDFDiesel is offline
