Alternative Fuels - Diesel - Additives - LubricantsDiscussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
__________________ 07.5 Chevy Summit White Reg cab LMM, 5" MBRP straight pipe, 6" tip DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Fass Sale for November pm for details.
I use Shear power HD 15w40 with soot control from BG products/fully syn.
__________________ 2005 LLY CCSB
Leather, Bose, XM
Truxedo bed cover, Line-X
285/75R/16 Toyo A/T's Ready Lift Leveling kit
B&W Turn-over-ball
MBRP 4" turbo back (soon)
Resonator plugged
NO CAT!!!!
Was going to go Juice and Att. but now probably going to do a PPE
Mobil delvac 15-40 weight,the 30 wgt thing is for EXTREME cold conditions...
__________________ MINE2006 GMC 2500HD4x4 sb cc LBZ!Got a couple lil mods,more to follow
[color="Blue"]02 GMC 1/2 ton,2wd,5.3 power{Mama's ride}
87 SS Monte Carlo 77k[orig!]
78 Malibe [2dr.]350/350 WORK RIG:03 YukonXLHypertech tuned!!310k miles! The left lane is used to pass,so get over,or we'll run over ya asssss!!1996 Impala SS on the way!!!
I would never trust autozone for starters and I reccomend Synthetic They disepate heat better and usually have better seal softeners and shift packages. I run our BG Universal Synthetic pulling I have never seen it over 150. Amsoil is an excellent choice as well.
Leather, Bose, XM
B&W Turn-over-ball
Resonator plugged
NO CAT!!!!
diesels of 20yrs. straight 30 is what was used primary, but then engines cranked hard in the winter below 30F so, you changed to thinner oil in the winter month's. Seems like it was sae 20 wt. So hence multi-weight was developed(15w-40).
__________________ 2005 LLY CC/SB 4x4/Allison, PPE Xcelerator, MBRP 4" turbo back, AEM workhorse intake,Outerwears prefilter, EGR blocker plate,Autometer pyro and boost, Westin W2W steps,Delta crossover box,Bilestein shocks,Energy Suspension sway bar bushings, Odyssey dry cell batterys, odc diff. cover,deep tranny pan
The manual says 5w40 or 15w40, so which one to use. Personally I like 15w40 year round. Are the tolerances in the duramax such that lighter oil should be used?
__________________ 2006 2500HD Crew Cab SB LBZ LT3
Dark Ming Blue Metallic
4" MBRP turbo down exhaust, straight thru Turbine muffler
Leer Premium 100XQ Canopy
245 Wrangler Silent Armor E's
AstroStart remote start w/full function remote
It isn't he tolerances...its the environment you drive in that should dictate what oil is used. Cold weather environments require "thinner" oil. I live in S.E.GA so I use 15W-40 Amsoil synthetic.
__________________ '06 2500 HD CC/SB BullyDog TripleDog AiRaid CAI MBRP 4" Turboback Goodyear Silent Armor LT 285/75R16 EGR blocked w/Fingerstick
