Top side creeper - Chevy and GMC Duramax Diesel Forum
Behind The Garage Door For your garage / shop including tools & equipment
Old 01-08-2013, 05:08 PM   eBay Motors  #1 (permalink)
Top side creeper
I am thinking about purchasing a top side creeper for under the hood work because it is starting to get hard on the knees inside the hood of a lifted truck lol. Didnt know if it is a good investment and if anyone else has used one. Thanks!
01 lb7 Crew cab short box
BDS 4.5 inch suspension lift
33" Mickey Thompson MTZ's on 17" Fuel wheels
4" MBRP turbo back exhaust
AEM cold air intake
Fass 150
Edge Insight CTS
Cognito pitman and idler arm braces
Tie rod sleeves
aconrad13 is offline   Reply With Quote
Old 01-08-2013, 05:20 PM   eBay Motors  #2 (permalink)
Goose2448's Avatar
We have one at work and its great for larger trucks. Only problem I have with it is laying on it for too long, and it can make some things harder to do. But being able to get at the back of a 7.3 in a 4x4 F550 is a nice thing.
2008 GMC 3500HD CC LB DRW 4x4~5" MBRP Filter Back Straight Pipe, Westin Step Bars, WeatherTech Floor Liners, Antenna "Delete", Plasti Dipped Grill and Emblems and Rims, Leveled, Funky Gear Rims, Nictane Adapter with Donaldson and Clear Bowl
1985 Chevy C20 RCLB 350 4 Bolt, 4 Barrel Carb, 4.10 Gears, 8600 GVW, Glass Packs Dumped, Pig Skin Leather, Bed Mounted 5th Wheel, Dual 20 gal Tanks, 62,146 Miles, Indian Bronze and Cream~Rolled
DF DRW Club Member 129
Goose2448 is online now   Reply With Quote
Old 01-08-2013, 05:40 PM   eBay Motors  #3 (permalink)
Spoolin' Up
Hibneck1's Avatar
I welded up a step that hangs off the top side of the tire and it sure is handy to reach under the hood of anything, even the big mud toys. Plus if you can weld it can be made of scrap
2006 Chevy 2500HD Duramax Allison ECLB
Mods: 5000k 55w HIDs in high, lows, 4300k 55w in fogs, all on mod, PPE Air box mod, blocked and stuck, PCV re-route and resonator kit, 5" Diamond Eye Turbo back with 7" tip, raptor liner from body line down and holding up perfect!
Waiting to be installed: Cognito 4"-6" with hd sway bar, ballistic jester camo 17x9 rims with 315/70 R17 Treadwright Guard Dog M/T's, Fabtech tie rods, pump rub kit, moog ball joints and pitman/ idler arm
Hibneck1 is offline   Reply With Quote
Old 01-08-2013, 05:54 PM   eBay Motors  #4 (permalink)
JOKER's Avatar
I have a tire step in my wheeler, but it isn't much good when the wheels are leaning against the shop wall. :P Example of tire step.
If you are under the hood/cowl often, top-side creepers are worth every penny in my opinion.
Proud Member of "the pup bros"
-'11 GMC Sierra HD 3500 SLE, CC/LB/DRW, LML, 4x4
-'91 GMC Suburban V2500
-'90 GMC Suburban V1500
-'90 Subaru Sambar (DURAMAX KILLER)
-'88 Chevrolet R20 3+3
-'86 GMC Sierra K35 3+3, SRW, mild-350/400/205/60/14FF(welded), 39.5s and 44s / 4" springs, X-over, m15000 rear winch, etc. THREAD
-'86 GMC K2500 reg/long, 350/465/205/44/14SF
-'82 Chevrolet S-10 reg/long/2WD
-Aluminum jet boat 427BBC/SD309
JOKER is online now   Reply With Quote
Old 01-08-2013, 06:21 PM   eBay Motors  #5 (permalink)
800polaris's Avatar
You don't have quite the leverage when you are trying break bolts loose, and yeah some situations are a little weird. BUT, my topside creeper is the pride and joy of my life. It is so damn comfortable, it makes me start to get sleepy working at night. This wasn't a problem before because of the excruciating pain in my knees and back. I highly recommend you own one if you plan on doing much under the hood of anything.
Curt
05 GMC ccsb slt 4x4 efi live 3"dp 5"straight pipe built trans airdog blocked rerouted lbz mp power steering
95 dodge eclb cummins 4x4 5sp slt
90 F-250 rclb 7.3 4x4
800polaris is offline   Reply With Quote
Old 01-08-2013, 06:41 PM   eBay Motors  #6 (permalink)
joegorby's Avatar
I have the foldable one. If I had to do it again I would buy the regular one. My foldable still takes up a lot of room.
Like said above you lose a lot of leverage when trying to break bolts loose but it was a great investment for when I put my new turbo setup on.
2010 2500HD LMM CCSB
Tuned by Blackout PerformanceBatmo S472 from EPR
AirDogII 200= PPE Dual Fueler= 45% Injectors
PPE Stage 5 with billet shafts=PPE C5 upgrade=Suncoast 1058 Built by Big Dipper
Kryptonite and Cognito Front End
Diamond Eye 4" straight pipe
Alligator Performance PCV reroute
AutoMeter Gauges
2013 GMC 2500HD Denali CCSB
Stock for now (H&S on the way)
joegorby is offline   Reply With Quote
Old 01-08-2013, 06:46 PM   eBay Motors  #7 (permalink)
KensAuto's Avatar
I use mine a few times a week, and it's a savior if you have a bad back, but it takes up a lot of floor space.
2012 GMC 2500 SLT 4x4
H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass
Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights
Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps
KensAuto is offline   Reply With Quote
Old 01-08-2013, 07:07 PM   eBay Motors  #8 (permalink)
Alright so seeing the posative feedback im set on getting one. Now the question is what brand?
AEM cold air intake
Fass 150
Edge Insight CTS
Tie rod sleeves
Old 01-08-2013, 07:11 PM   eBay Motors  #9 (permalink)
KensAuto's Avatar
I think mines actually called 'topside creeper'
Old 01-23-2013, 02:38 PM   eBay Motors  #10 (permalink)
19psi's Avatar
I love mine. Got it from NAPA.
07 LBZ 4x4 1LT Banks Speedbrake, EFI Live, 18x9 MotoMetal961, 325 60 18 Terra grapplers,Alligator ffa with CAT filter, PCV dumped to atmosphere as god intended, 5" turboback, HIDs, LED's, downpipe, ATS rear diff cover, Bilstein 5100s, Pioneer AVIC Z2, Planet Audio 12" subs, Cerwin Vega amp. Rockford fosgate amp,Transgo JR, EGR blockoff, PPE race valve.Dyno'd 3/24/12 402hp, 734tq
19psi is offline   Reply With Quote
