Thanks a lot to
JHendrick1 for this write up and Pics
Having factory installed mud flaps, and having to take off the passenger front wheel well liner every time to properly drain the water and/or replace the fuel filter, seemed a bit ridiculous. Therefore, I did the following:
1) Purchased a new replacement passenger front wheel well liner from the GMC dealer for about $39.00 US dollars.
2) Cut out a section of the old liner so as to not disturb the two positive notches (see photos) that would be my “on-location” points during reinstallation
3) Cut out a new section to over-lap my cutout, being sure not to disturb the natural location and function of the liner
4) I wanted multiple contact bolt points, so I chose some self-locking J-type cage nuts (see attachment)
5) I took the photos to illustrate that the panel can be removed while the truck is on the ground, in the natural driving position. I was in the process of draining the water from the fuel filter, after doing an oil change. I took my previous and current trucks (2000 Ford F250 SD V-10 gas – 255,000 miles – replaced by GMC 3500) and (2004 Ford F350 SD V-10 gas – 176,640 miles) to higher mileage by keeping up on filter replacements & oil changes
6) Had this been engineered at the GMC factory, it would have been a huge success.
7) ** IMPORTANT –
a. Take out the OEM liner (with cutout) and overlay & clamp the new access panel, so as to drill both together assuring an aligned fit
8) Next project is to engineer a change to keep the “!@#$%^&ing” extended cab split rear seats up while driving. Gravity allows them to come down on top of cargo behind the driver’s seat. My Ford Super Duty’s always locked, but on the GMC’s does not…Love the LMM Duramax + Allison, so I’ll deal with it…for now.
Hope this helps
