My duramax rattles at low med rpm's. I dosen't matter if it's cold or warm. Has anyone run across this trouble, and is there a cure. It sounds like a rod knocking. People look at me like i'm crazy. I love my truck, but i can't take much more.
does it sound like in the old days when you got bad gas and the valves rattled or if you had the timing advanced to far? if so that what mine sounds like don't remember having this before ulsf maybe my memory is bad though
My LBZ has a rattle at low rpm, durning acceleration. It sounds like its coming from the right side of the truck underneath the cab. (I know thats where its at I have checked into the problem already). That is generally just a loose heatshield that is vibrating due to the engine increasing in speed. Might want to check into that.
Other than bone stock, where does it sound like its coming from? Does it do it at idle, or like mine low RPM during Acceleration? If like mine, sit / stand carefully in the bed and give a good hard listen. Check the bolts underneath the truck and ensure everything is snug like it is supposed to be.
Hope this helps!
__________________ 2007 GMC Sierra 2500HD Classic (LBZ)
EFI Live
MBRP 4" Stainless Exhaust
S&B Cold Air
Drivers Side Exhaust Manifold
EGT Gauge, without pillar mount. Instead Redneck Mounted! 100HP Tune Courtesy of Idaho Rob!
Repeat Customer, Killeen Tx Discount Tire. Visit them online www.discounttiredirect.com
i had the same thing as soon as i put my 4" exhaust in...just at low rpm.......i figured the pipe was hitting the heatshield so i began whacking the heatshield and it seemed to fix it.
cheers,
TM
__________________ 06' LBZ 2500HD CC shorty
BD 4" turbo back exhaust dual 5" tip (straight piped)
6" tuff country lift
LT315/75R16 BFG all terrains
Cognito HD tie rods
16x8 eagle alloy series 185
all around tint
line-x
resonator plugged
Amsoil from Chris (bigdaddydiesel)
sorry.... that was in resonpe to anthony.jackson84's post
TM
Cognito HD tie rods
all around tint
line-x
resonator plugged
