Old 05-18-2009, 02:09 PM   eBay Motors   #21 (permalink)
Dmax15
Dmax15's Avatar
Here you go.
LB7: 01 Fuel Injection Pump Replacement - Duramax Diesels Forum
2002 GMC LB7
EFI live tuning from IdahoRob
http://www.atptrucks.com
12.34 @ 108.7mph
Dmax15 is offline   Reply With Quote
Old 05-18-2009, 02:11 PM   eBay Motors   #22 (permalink)
Dmax15
Dmax15's Avatar
Here are pics from my cp3 replacement, just so you know what to look forward to.
2002 GMC LB7
12.34 @ 108.7mph
Old 05-20-2009, 08:04 AM   eBay Motors   #23 (permalink)
Birddog
Just replaced the FPR in my 05. Just wanted to thank all that replied and sent info. It actually wasn't that bad of a job to do. I didn't have to disconnect half of what the intruction said to do. I just went after the FPR and removed what was necessary. I also used a 3 inch torx bit and a 1/4 wrench to remove the FPR screws. I ran a magnet across the tip of the bit which helped hold the bit in place as well as extract the screws which also helped to intall them. It took about 3 hours start to finish. The truck runs much smoother. Thanks again.
2005 GMC 2500 HD Duramax. Bully Dog Power Pup, 4" exhaust airaid intake system.
2008 Chevy 3500 HD Duramax. Edge Evolution
Birddog is offline   Reply With Quote
Old 05-20-2009, 08:59 AM   eBay Motors   #24 (permalink)
HECKS
HECKS's Avatar
How much for a new FPVR ?
2005 2500HD LLY CCSB 4x4
AFE INTAKE STAGE II
5" HUSKER STRAIGHT PIPED, EGR DELETE
PPE HOT+2 E.T.
AUTO METER PHANTOM WATER/PYRO/BOOST GAUGES
BD EXHAUST MANIFOLD, AFE BLADERUNNER,
SUNCOAST IV NADP HEAVY HAULER TRANNY w/ DEEP PAN
COGNITO BRACES, 20" A.R. RIMS w/ BFG AT'S 305/33
HECKS is offline   Reply With Quote
Old 05-20-2009, 06:09 PM   eBay Motors   #25 (permalink)
Birddog
I bought mine from Oregon Fuel Injection not from the dealer. With shipping I spent $180.00
Old 05-20-2009, 07:19 PM   eBay Motors   #26 (permalink)
03lb7dmax
03lb7dmax's Avatar
i have to replace mine soon is their any one that is better than the stock like a performance one and what would a shim kit do for it ? thanks
2003 chevy cc,sb 4x4
Engine: LB7 6.6 duramax diesel
Transmission: allison 1000
Mods: transparts stage IV, S/C 1056 converter, EFI live w/ DSP2, LBZ fuel pressure regulator, 5" flow pro exhaust 6" dual wall tip, airdog 150, PPE billet pickup tube, K&n cold air intake, LB7 mouth piece mod, tripple piller gauge mount w/ fuel pressure,egt and boost, GM touch screen navigation, extang soft bed cover, tow mirrors, debadged
Wheels & Tires: 20"x10" eagle wheels and 33"x12.5"x20" nitto mud grapplers
03lb7dmax is offline   Reply With Quote
Old 05-21-2009, 10:51 PM   eBay Motors   #27 (permalink)
mookie980g
mookie980g's Avatar
1. Remove the air intake pipe. Refer to Air Intake Pipe Replacement .
2. Disconnect the air conditioning (A/C) compressor clutch electrical connector.
3. Disconnect the A/C cut out switch electrical connector.
4. Remove the drive belt. Refer to Drive Belt Replacement in Engine Mechanical - 6.6L.
5. Remove the A/C compressor bolts.
6. Move the A/C compressor with the hoses attached to the right side of the engine compartment.
Object Number: 674653 Size: SH
Click here for detailed picture of above image.
7. Remove the water outlet tube. Refer to Water Outlet Tube Replacement in Engine Cooling.
8. Disconnect both main harness electrical connectors.
Object Number: 674680 Size: SH
9. Remove both main harness electrical connector to bracket bolts (1).
10. Remove the main harnesses from the bracket.
Object Number: 740506 Size: SH
11. Disconnect the engine coolant temperature (ECT) sensor electrical connector (1).
Object Number: 739503 Size: SH
12. Disconnect the barometric pressure (BARO) sensor electrical connector (1).
Object Number: 786978 Size: SH
13. Disconnect the glow plug relay electrical connectors (1, 2, 3).
Object Number: 786977 Size: SH
14. Disconnect the fuel rail temperature sensor electrical connector (1).
Object Number: 786986 Size: SH
15. Disconnect the left front fuel injector electrical connector (1).
Object Number: 786988 Size: SH
16. Disconnect the left rear fuel injector electrical connector (1).
Object Number: 786996 Size: SH
17. Disconnect the fuel pressure regulator electrical connector (1).
Object Number: 788846 Size: SH
18. Disconnect the oil level sensor harness electrical connector (1).
Object Number: 687021 Size: SH
19. Remove the positive crankcase ventilation (PCV) hose from both valve covers.
Object Number: 901298 Size: SH
20. Reposition the injection pump inlet clamp.
21. Remove the injection pump inlet hose from the fuel feed distribution (leak-off) block. Reposition the hose.
Object Number: 901300 Size: SH
22. Clean the fuel pressure regulator and high pressure injection pump thoroughly with solvent, such as GM P/N 12377981 (Canadian P/N 10953463), or equivalent.
23. Using compressed air, thoroughly blow dry the regulator and pump.
24. Remove the 3 fuel pressure regulator screws (1) using a T25 TORX®.
Object Number: 901301 Size: SH
25. Remove the fuel pressure regulator (1). Important: DO NOT use compressed air to remove debris while the fuel pressure regulator is removed.
1. If dirt or debris is found in the bore or seating surfaces of the fuel injection pump, perform the following:
1. •
Place a clean rag over the pump bore in order to collect the excess fuel.
• Bump the engine over in order to flush any debris out of the regulator bore.
2001 Chevy 2500HD CC\SB D-MAX\allison 5spd
1500series torsion keys to level it
PPE STANDARD 160 HP TUNE
Raptor 150GPH Lift Pump, aFe stage I intake,
5" MBRP W\6" Tip, Autometer Cobalt boost and pyro guage
KenWood Flip out,MTX 2 10" subs, MTX amp
windows tinted, HID's, smoked tail lights,Recon Roof lights, N-Fab Nerf Bars.
BEST TIME 15.145@91.35 ENGLISHTOWN RACEWAY PARK
mookie980g is offline   Reply With Quote
Old 05-21-2009, 10:53 PM   eBay Motors   #28 (permalink)
mookie980g
mookie980g's Avatar
this is the instructions with no pics it wnt work
Old 05-21-2009, 10:53 PM   eBay Motors   #29 (permalink)
mookie980g
mookie980g's Avatar
ALLDATAdiy.com - 2001 Chevy Truck K 2500 P/U 4WD V8-6.6L DSL Turbo VIN 1 - Service and Repair
Old 05-21-2009, 10:56 PM   eBay Motors   #30 (permalink)
Dmax15
Dmax15's Avatar
Yes wicked diesel sells one for like $175 or something, same price as a replacement IIRC. Since you have EFI live you can make it work using table b1010.
2002 GMC LB7
12.34 @ 108.7mph
