Old 04-16-2009, 05:50 PM   eBay Motors   #1 (permalink)
haugenJ
05 duramax squeeling noises
I am new to this site so forgive me if i'm in the wrong section. I 'm looking for some help. My 05 duramax with 60,000 miles is making a squeeling/chirping noise under the hood. It only does it at 1300 to 1500 rpm but only after it has warmed up. dealer said it was a belt so they changed it and it still does the same thing. Any one with some answers
haugenJ is offline   Reply With Quote
Old 04-16-2009, 06:19 PM   eBay Motors   #2 (permalink)
dmax4u44
dmax4u44's Avatar
try a goodyear gatorback belt, check alternator bearing, idler pulley's? been known to take a crap, check for slop
dmax4u44 is offline   Reply With Quote
Old 04-17-2009, 09:15 PM   eBay Motors   #3 (permalink)
haugenJ
I'll try that. Thanks for the info. sweet truck!
Old 04-17-2009, 09:20 PM   eBay Motors   #4 (permalink)
usafracer
Red trucks rule.
usafracer's Avatar
I see you live in Why not Minot LOL. More than likely you run your truck on defrost a lot and that will cause your a/c compressor to cycle to help remove excess moisture from the air in the cab. The chirp you hear is the belt slipping every time the compressor kicks on.
As mentioned a quality belt like the Goodyear gatorback should cure your problem. While you have the belt off don't forget to look over all the other accessories to make sure they are in good working order.
2008 GMC Sierra Crew Cab 4X4
2004 CC/SB 4X4 Duramax (sold)
Old 04-17-2009, 09:48 PM   eBay Motors   #5 (permalink)
haugenJ
thanks for the help. your truck sounds like a wild ride. Awsome!!
Old 04-17-2009, 09:58 PM   eBay Motors   #6 (permalink)
lubeman1969
lubeman1969's Avatar
Been there and done that...alternator in my case. New belt only cured the noise for about a week.
2006 2500 LBZ CREW CAB LONG BED * NFAB STEP BARS
35" TOYO OC MT"S W/ 18" ROCKSTARS * FABTECH 6" LIFT * FABTECH HD TIE RODS
BD FULL BORE MANIFOLD * S&B CAI
4" STRAIGHT PIPE EXHAUST * MBRP 5" TIP
TRANSGO JR 4/11/09...THIS WAS A GREAT MOD!!!
BANKS INTERCOOLER * RESONATOR HOLE PLUGGED
EGR BLOCKER PLATE * EDGE INSIGHT MONITOR
TUNED WITH EFI LIVE>>>NOTICE I AM SMILING!!!!
www.huskerdiesel.com
lubeman1969 is offline   Reply With Quote
Old 10-28-2009, 11:47 AM   eBay Motors   #7 (permalink)
WYNAVY
My 04 and my dads 05 are doing the same thing and i have narrowed it down to the exhaust clamp, and you can not tighten the clamp enough to fix it. I talked to my dealership and they said there is a bulletin on it and they can install 2 "vibration dampeners" on the exhaust pipe 17" before the cat. and that will fix it. My dad did this cause his is under warrenty and it fixed his. My problem is that the dampeners are 85.00 a piece.
WYNAVY is offline   Reply With Quote
