There are several things needed when working on your truck in the heat!
I picked up a cheap bulb pump and drained all the old brake fluid in the reservoir out. I used a keeper pin to keep the hose from flopping out of the drain pan.
Next: just pour in the New Fluid, Fill to the MAX line. and replace the cap on the Reservior.
Be sure to check after each wheel topping off the reservior.
You will start at the Right Rear, Left Rear, Right Front, and finish at the Left Front.
I then connected a one man Bleeder Kit. AutoZone for like $6.99
You will have to plce the bleeder bottle at a point abover the bleeder screw, mine had a magnet.
Next insert the tapered adapter into the bleeding screw hole.
Open Bleeder Screw 3/4 to 1 turn
Now press the brake pedal fully three to four times (I only did 3 since 4 would over fill the bottle and leak out)
__________________ Matt
2005 Chevy 3500 4x4 SLT Crew Cab, L O N G BED! Leather, Integrated DVD Player,"you know, for the kids!" Banks CAI, PPE ECON stage 2 Installed by BigRedChevy; MBRP 4" SS. Dead CAT Kept the MUFF, Modded turbo mouthpiece
RESONATOR PLUG,EGR Blocker Plate Putco Boss Barz Fat Mud Flaps "Wake up AMEARICA!"
you will see the dirty brake fluid clear after about 5 to 6 cycles.
I cheat when bleeding brakes. I have a vacumn gun!!!!! Nice write up too!!!!
I'd like to see that, I almost went that direction but couldn't let go of the $50 for it.
That brake fluid has about 72,000 miles on it.
Drives Great!
but I'm not done, I'm adding more brake and Power Steering fluid when it gets here.
