I just purchased three Pump Rub Prevention Plates from Kennedy; one for me and two for my buddies Z71s.
I could really use some advice on the best/easiest way to drop the Transfer Case. The plate install seems straight forward, as described by Kennedy Diesel.
I am unsure as to how to disconnect the drive shaft from the U-joint, or if that is even necessary?
Thanks in advance for the assistance.
__________________ Doc5339
2003 Chevrolet Silverado K2500HD Crew Cab Duramax LB7
Diablo Sport Predator (set at 65hp "Economy")
Silverline Exhaust
Cooper Disoverer ATR "E" Range Tires 265 75 16
95 GPH FASS with 0.3 Micron Filter
Pyrometer and Manifold Gauges
BioDiesel (B30 and B99) from OM Fuels
Line-X Bedliner/CamLocker Tool Box with Line-X Coating
Pioneer Navi with Sirius Satellite Radio, iPod direct hook-up, and hands free Bluetooth calling
Nope, just disconnect the drive shaft from the rear end, and slide the drive shaft out.
__________________ '05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
How do you disconnect the drive shaft from the rear-end? I am guessing you mean the rear diff? How do you disconnect it?
Silverline Exhaust
believe there are bolts on the rear u joint (IIRC), should be four 10mm??
Thanks K9! It seems almost too easy; then again most of the advice I have gotten starts with "easy," yet I ALWAYS find a way to make it difficult.
I really appreciate the super-quick reply!
Silverline Exhaust
LOL, driveshaft will be the least of your problems.....
So here is what I am expecting after I drain the Transfer Case:
1. Remove Frame Cross-Member below Drive Shaft
2. Disconnect Drive Shaft at Rear Diff.
3. Unbolt Transfer Case from Tranny.
4. Drop Transfer Case.
5. Crack open Transfer Case
6. Remove Pump/Internals.
7. Install Anti-Wear Plate.
8. Re-Install Pump and Internals.
9. Put everything back like I found it!
Is it really this EASY? Where will it suck most?
Silverline Exhaust
not trying to sound like a asshole but if you need to ask how to take the drive shaft out , i really cannot see you splitting the case and installing everything properly.
i recommend if you are able to get the t case out to take it to someone that knows them.
__________________ 02 LB7
4" down pipe back exhaust
ported intake horn
S & B filter
35" tires
I appreciate that Duckman, thank you. I do not consider myself a mechanic, though I do most of the work on our two diesel trucks. I really cannot afford to pay my local wrench to do this.
I have successfully replaced the Front Axle Seal, Hydro Boost, and done all scheduled maintenance. Kennedy has some pretty detailed instructions on how to crack the TC and to install their part, so I think I gotta take a crack at it. I will probably do my buddy's truck first though!
Silverline Exhaust
