Old 11-09-2009, 02:55 PM   eBay Motors  #101 (permalink)
skippe's Avatar
I hooked mine up under dash as stated and on high beam all are on. On low beam I still have to push fog light button for them to come on.
09 2500HD CC LTZ
6" PROCOMP Lift 20" MOTO METAL 951
35" TOYO M/T
skippe is offline   Reply With Quote
Old 11-09-2009, 03:20 PM   eBay Motors  #102 (permalink)
Seminole's Avatar
thats the way mine is that way if a cop or something or someone comes up on ya. Like the other day this person seen me coming and still turned in front of me and I turned on all of them,the lady in the passengerside was sqwinting hahaha.that was cool touch of a button does wonders
2008 GMC CrewCab Z71 4x4 LTZ black
20in' RBP with Cooper Zeons
0% rear,20% front tint
Antenna Delete
Readylift leveling kit
80 gal aux tank bed level
pvc reroute
Seminole is offline   Reply With Quote
Old 11-09-2009, 03:53 PM   eBay Motors  #103 (permalink)
Shake and Bake
rap2orrider660R's Avatar
Yep !!! Ok, I got this to work, and it was working all a long... I thought they automatically come on even with the low beams on.... I put the diode back in and then hit the hi beam and the fogs were on...
Now, is there a trick to getting the fogs to come on automatically when either lows or highs are on... I am getting tired of turning them on everytime I start the motor up for the low beams ??
Aaron Blackwell
Cen-Tex Marine
Proudly Serving the Marine and Oil Industry
2007.5 D-MAX, EDGE DIGITAL GAUGES, QUADZILLA WITH DPF DELETE, TUNED AT 90HP NO MORE NO LESS, STRAIGHT PIPED, 17" CHROME SHAKER RIMS WITH 285 70 17 BFG KM2 MUD TERRAIN TIRES, AIR BOX MODIFIED,BUSHWACKER BED CAPS, RECON SMOKED LOW PROFILE CAB LIGHTS AND MORE TO COME (I HOPE)
rap2orrider660R is offline   Reply With Quote
Old 11-09-2009, 08:54 PM   eBay Motors  #104 (permalink)
GWEEDO!!!!
RedBowTies88's Avatar
run a diode from low beam pin 85 to foglight pin 85..
point the stripe towards the lowbeam
Beech (thats my real name) EfiLive by Nick@duramaxtuner, likes to go fast
CC/SB LLBYE
Originally Posted by DMAXchris View Post
No one ever said anything about lube or salami you sick bastard.
Old 11-10-2009, 10:07 AM   eBay Motors  #105 (permalink)
Follmer's Avatar
Originally Posted by Gangkopff View Post
I just did the mod on my 2001. You have to do both the driver's side and passanger's sides but it is super easy. You cut the yellow wire from the low beam light socket and ground it. Make sure you cut it long enough so that it will reach your grounding point. I just tucked the cut end (harness side) back into the harness. It took 10 mins. to do both sides and onlt requires two crimp connectors. I can't wait for dark!
how did u get the fog lights to function with the low beams, high beams and fog lights??
-Josh
2004 2500 LB7
Follmer is offline   Reply With Quote
Old 11-10-2009, 10:14 AM   eBay Motors  #106 (permalink)
Gangkopff's Avatar
I don't have fog lights on mine. I was just interested in the high/lows. Sorry
2001 GMC LB7 2500HD Reg Cab Long Box 4x4
S&B Intake
Custom 4" Stainless exhaust split dual
Edge Juice w/Attitude
PPE Boost Valve
Turbo Air Horn Mod
35% Tint
http://www.alligatorperformance.com/
http://www.meyerperformance.com/
http://www.madjacksynthetics.com/
Gangkopff is offline   Reply With Quote
Old 11-10-2009, 10:33 AM   eBay Motors  #107 (permalink)
Gangkopff's Avatar
check your fuse box relays
Since you have a 04 you will probably have to run 1N4004 diodes from your high beam relay to your low beam and fog light relays. My 2001 does not have seperate high/low relays. I have one relay for both. I think your mod is covered in the begining of this thread.
S&B Intake
PPE Boost Valve
Turbo Air Horn Mod
35% Tint
Old 11-10-2009, 12:14 PM   eBay Motors  #108 (permalink)
Seminole's Avatar
direct hook up
I think you got to hook them up straight
Antenna Delete
pvc reroute
Old 11-13-2009, 01:02 PM   eBay Motors  #109 (permalink)
alright... im going home this weekend.. to help my friend (truck in the sig is his) do the pcv reroute and im going to do this too?.... dumb question though?? whats the purpose of the diode? i did this on my ford with the fogs and i didn't need a diode.. just some extra wire.... help?
2005 LLY ext. cab 2500
4'' Turbo Back straight pipe
Suncoast stage 4 tranny
AFE stage II Pro gaurd 7 intake
EFI LIVE BY ROB
DSP 5 SWITCH
FASS 150
HD tie rod sleeves
Autometer gauges: egt, boost, trans
18x10 ion wheels with 33x12.50 Nitto Terra grapplers
09 LED Cab Lights and tow mirrors
Durablack05 is offline   Reply With Quote
Old 11-13-2009, 02:10 PM   eBay Motors  #110 (permalink)
I Drive a gasser
02CoalRoller's Avatar
A diode allows electricity to only flow in one direction. If this were done with a wire instead of a diode, I believe that even with the low beams on, you will get high's also. Maybe the fords are set up differently. Hope this helps!!
09 Silverado 1500 LT CCSB 4x4 4.8L
White
06 Suzuki GSXR 1000
Black and White
SOLD 02 Silverado 3500 LB7 RC DRW
White
02CoalRoller is offline   Reply With Quote
