__________________ 02 Chevy LT ec/sb 300k
265/75/16 Toyo Open Country
8' Fisher SS Xblade
PPE Boost Valve
5" MBRP dp back
Autometer Phantom II Boost and Pyro
Quadzilla Stealth 2 at 50hp
REAL TRUCKS DONT HAVE SPARK PLUGS sticker across my rear window
no you got to look at mine for 07- 08 trucks on up
__________________ 2008 GMC CrewCab Z71 4x4 LTZ black 20in' RBP with Cooper Zeons
0% rear,20% front tint
Antenna Delete
Readylift leveling kit
80 gal aux tank bed level
pvc reroute
can i get this diode at advanced auto parts? my radio shack down a while back?
__________________ Joe, 22
2008 CC LB LT2 DURAMAX LMM
MBRP 4" TB back(NO CAT, NO DPF, NO MUFF), Quad II on 70HP, autometer phantom II pyro and boost gauge, tie rod sleeves , 15% tint, 5" G.M. nerf bars, gm vent shades and bug deflector (EGR plate still waiting to go on)
next on the list
transgo jr, spray in bedliner, 285 BFG A/T
special thanks to
nate @ www.performancetruckproducts.com tyler @ www.meyerperformance.com
chad @ http://www.alligatorperformance.com jimmy @ www.getsomeperformance.com
I don't know if you can or not, never tried hope you get it figured out
Antenna Delete
pvc reroute
I just did the mod on my 2001. You have to do both the driver's side and passanger's sides but it is super easy. You cut the yellow wire from the low beam light socket and ground it. Make sure you cut it long enough so that it will reach your grounding point. I just tucked the cut end (harness side) back into the harness. It took 10 mins. to do both sides and onlt requires two crimp connectors. I can't wait for dark!
__________________ 2001 GMC LB7 2500HD Reg Cab Long Box 4x4
