This is a write-up for how to make your low beams and/or fog lights stay on when you switch to high beams...This mod costs all of about $1 and should take no more then 15 minutes..its very very easy and use's the trucks own built in fusses and relays. Credit for this goes to Will from duramax diesels...i just made some additions and modifications..
All you need is a set of diodes that you can get from your local Radio Shack. The part number that I used was 1N4004. I have read that 4001,4002,4003 and 4004 will all work. These diodes come in a 2 pack and cost $.97.
You will do this mod under the hood at the fuse block on the drivers side of the truck. Make sure that the truck is off before reaching in there. You shouldn't need to unhook the batteries or anything like that.
On the bottom of the relays is the numbers for the different pins. You will be using the 85 pin for these mods. Also, on the bottom of the lid of the fuse block is a diagram showing the numbers of the pins along with which relay goes where. The 3 relays that are used are in the lower left hand corner of the fuse block
Hi-lows on at the same time.
You will need to connect the 85 pin of the low beams relay to the 85 pin on the hi beams relay. Make sure that the "bottle cap (or end with the stripe)" is going towards the hi beam relay. You can either wrap the wire around the metal pin or slide it into the hole that the pin goes into. Either will work.
Hi-fog on at the same time.
For some reason GM decided that when your high beams are on, your fog lights don't need to be(actually i believe this is a law) . Well I like my fog lights on adding more light. With the hi beams on adding a lot of light, then the fog lights on adding more light can't be a bad thing right?
To do this you will need to connect the 85 pin of the fog lights to the 85 pin of the hi beams. Make sure that the "bottle cap (or striped end)" is going towards the hi beam relay. Again you can either wrap the wire around the pin or push it into the hole that the pin goes into. If you are doing the lows plus the fogs it can be a little tight on the 85 pin of the hi beam pin. For this I wrapped one diode around the pin and the other got pushed into the hole with the pin(i pushed both into the slot...they fit you just need to push down hard on the relay) . You will still have control of your fog lights on low by switch but by doing this the fog lights will always be on with hi beams.
This Mod works perfectly with HID's as well as regular bulbs.
The pic shows how I have it wired. Sorry for the poor picture but hopefully the labels will help better explain things. the second pic is what the diode pack looks like from radioshack..its on the left
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Nice.. I should do that I hate having fog lights off. I would like to just make them on 24/7. I am tired of hitting the button. I light them on all day with markers.. And same thing no matter what light is on they should be. They look awsome.
-JIM- '08 LMM CCSB LTZ
4-6" MBRP Black Miter Stack - DPF Delete - EFI Live Tuned by HUSKER DIESEL - ISSPRO EV2 LTZ/LMM MATCHED BOOST/PYRO on Pillar - aFe intake - Plugged Resi - EGR Block Off - Transgo JR. - PPE Tie Rod Sleeves -Reflex Liner Grill, bumpers, bed over rails, rear wheel wells - Debadged & custom 6.6L Black on tailgate, DURAMAX on doors - Black bow ties - Flat Black H2 Wheels w/ BF Goodrich T/A 265/70-17 - Tint
thanks brain... i noticed most guys over here didn't know about it
thats possible....uh..if you ran a diode drom the daytime running light relay pin 85 going to the foglight relay then whenever they came on the fogs would be on..
Sweet...thanks seth
LLY Cc/sb 4x4 RED
Sweet Im saviing that.. Radio shack on lunch break and i'll go out on my boring day at work and see if I can't set something on fire haha
in the second picture, what is the second package? i want to do this!
__________________ Joe, 22
2008 CC LB LT2 DURAMAX LMM
MBRP 4" TB back(NO CAT, NO MUFF), Quad II on 135HP, Tie rod sleeves , 15% window tint all the way around, 5" factory gm running boards, gm vent shades and bug deflector
dont worry about that...you only need the one on the left...ask the radio shack dude for diodes then go to the drawer and look for number IN4004...if they dont have those 4001,4002,4003 will work as well
LLY Cc/sb 4x4 RED
I did this on my other chevvy and it's gret just havent done it on the d-max YET...acutally now that this thread made me think about it I'm gonna go do it tonight...with daylight saving BS it's almost dark at 5 when I leave work so I will get plenty of use
__________________ DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
