06 lly fuel rail pressure sensor problems - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 01-17-2010, 02:58 PM Thread Starter
Angry 06 lly fuel rail pressure sensor problems
I have a 06 lly duramax with 6 gun banks tuner with pda read out, 5 inch dimond eye exgaust, 6 inch lift, 35 by 12.50 tires and banks cold air intake. My dad started my truck and it sounded different. I wasnt there so i dont know exactly what was different. The check engine light came on and it said low fuel rail pressure and was in limp mode. It wouldnt go over 2000 rpm and got worse. It might of happened before but i didnt know because i didnt have the pda to check it. He shut it off and cleared the code and no more problem what could it be any ideas?
Last edited by rayrenner4; 01-17-2010 at 03:03 PM. Reason: for got to add some stuff
rayrenner4 is offline
post #2 of 12 (permalink) Old 03-09-2011, 06:52 PM
All it is that you have a low fuel pressure reading in your fuel rail. All you have to do is put a shim kit in it, which the kit cost like 12 bucks... If that doesnt solve the problem, then you probebly have to buy a lift pump
chanwagey is offline
post #3 of 12 (permalink) Old 03-09-2011, 07:08 PM
jbrown1132's Avatar
how old is the fuel filter? worth changing if it has been some time since the change.
'05 GMC 2500HD (white) slt cc sb 4x4
efi-tuned by idahorob, egr blocked, pcv rerouted, lift pump, kodiac mp,autometer sportcomp gauges, turbo dp, 4" ss magna flow exhaust straight piped, firestone ab, kool-vue towing mirrors, 5th wheel hitch with slider, gooseneck hitch.
305 MT ATZ's on eagle alloy 17x10
jbrown1132@yahoo.com
alligatorperformance.com
atptrucks.com
Truck is sold....
jbrown1132 is offline
post #4 of 12 (permalink) Old 03-20-2011, 09:14 PM
I am having the same problem but with a stock 07 LBZ. It likes to do this when i tow and decide to pull a hill in 5th. even with a brand new filter it will do it like clock work. Did the shim kit work?
gearhartfarms is offline
post #5 of 12 (permalink) Old 06-17-2011, 07:40 PM
You can do the shim kit, but it's better/more reliable IMHO to just install the PPE race FPRV and a lift pump instead.
If you are losing rail pressure from leakage these two will fix your issue.
I'd also suggest something like an Edge CTS where you can monitor demand vs actual fuel rail pressure to see if that is your issue.
MTL_Dmax is offline
post #6 of 12 (permalink) Old 06-17-2011, 07:52 PM
Vanned this place
TheStepChild's Avatar
STOP IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
THE SHIM KIT IS NOT A CURE ALL!!!!!!!!!!!!!!!!!!!!!
I'VE READ WAYYYYYYYYYYY TOOOOOOO MANY post saying shim it. and then it doesnt fix it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
stop stop stop
I'm STILL on my stock, unmolested FPRV
STOP IT NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:rockin
Heyyaa
Originally Posted by Jeremy Clarkson View Post
Some say he was conceived in a cargo van
TheStepChild is offline
post #7 of 12 (permalink) Old 06-17-2011, 08:00 PM
drzsz's Avatar
go the route im going and get a lift pump. when i cranck my edge up to hot it drains the fuel rail. i dont get any codes but u can feel it startting to studder and carry on.
04 gmc sierra
5 inch downpipe back with a 3 inch downpipe, efi live, ultralite II gauges, custom 5 inch intake, stage 5 trans build, high flow y bridge, egr delete, ported fuel rail fitting/plug, pump rub kit, lml manifold, intercooler pipe, lotsa white powdercoat, airdog 165 factory fuel filter deleted, tierod sleeves, idler and pitman arm supports, cervinies cowl induction hood, 20x10 eagle alloys, 37 12.50 20 nitto trail grapplers,rough country lift, all leather interior with camo seatcovers, halo headlights, alpine doubledin.
drzsz is offline
post #8 of 12 (permalink) Old 06-17-2011, 08:02 PM
Vanned this place
here's what cured my 0087s
Dealer fixed my LBZ 0087 - Duramax Diesels Forum
and the fuel line fix
post #9 of 12 (permalink) Old 09-07-2011, 06:21 PM
KC7
i have got a buddy with an 06 dmax thats doing the same thing....what was the problem and how did you fix it....we just ordered a new fuel pressure regulator and we just put on a airdog 150 system on it which helped for a while but the truck now still wont go above 1900rpm help please
KC7 is offline
post #10 of 12 (permalink) Old 06-14-2013, 08:46 AM
I have a customer that has the same problem. he is getting a p1093 code. he put in a new regulator on the rail first. then I put shims in the new regulator. Then I put an air dog on it and it still wont pull a heavy load especially when going over a steep grade with out pulling that code. I am thinking of putting in the race valve.
jcarrillo is offline
