Well, I bought a EGR blocking plate last night and the guy also had the WIF wrench's for sale. After reading this thread, I decided to go ahead and get a wrench also. $18 on Ebay. I know, shoulda bought from one of the sponsors. Tried to get a EGR plate but no one had any. (At least the ones I asked)
I will add too though, especially with the LMM's, that the grease is boo-koo bad if it gets into the injectors and the DPF. The burned grease smoke/soot can cause problems on the emission sensor crap.
Also, I see you used the "white" plumbers tape. When wraping threads for ANY petroleum based component, the "white" is a no-no.
For petroleum based and/or LP/natural gas pipes/tubing etc.... one needs to use the "yellow" thread tape. The yellow doesn't decay as does the white tape when prolonged contact/exposure with petroleum based chemicals hits it. i.e. Diesel fuel etc....
x2 diesel lubricates o-ring well enough
__________________ 2008 silverado dmax LTZ, aFe stage 2,race tune from idahorob,EFI LIVE, AD 150 lift , ppe shim kit,dpf delete,EGR block off plate,autometer gauges (cobalt) boost and pyro,transgo jr,6"fabtech with maxxcams and 2"addleaf,fabtech tierods,37"procomp 20" boyd wheels. 5% tint all around,5"grandrock stack kit,straight piped, custom painted dash panel,SCIV coming maybe
Use of channel-lock pliers vs WIF wrench depends on how tight the previous goob (GM or previous owner) put it on. My first attempt with LARGE (and they gotta be large to get a decent angled grip) channel-locks was not pretty due to it being very tight and the plastic being fairly delicate. IMHO - go with the WIF wrench if you wanna avoid damaging the sensor.
__________________ 2007.5 GMC 3500, LMM, SRW, 4 x 4, Crew Cab, 6" RCD lift, Nitto Terra Grappler AT 325/60/18 on Diamo 18x12 Alloys, Firestone Air Bag Suspension, Transfer-Flow 50 Gal Aux Fuel Tank, PPE Xcelerator Economy
I appreciate the write-up and especially the pictures. It gave me a good starting point. I have an 08 2500HD with the LMM engine (22,000) and during a recent trip out west the fuel filter reminder timed out so when I got home (AL) I bought a Baldwin BF7827 and proceeded to change it. I removed the air intake duct on top of the engine to give myself more room but quickly realized that my big hands would not fit down beside the filter. I remembered from other posts on this forum that some have removed the tire and finderwell so I proceeded to do that. This added about 30 minutes to the overall proceedure but really gave good access to the filter. I recommend it!!
As for the teflon tape, DON'T use it. That's just a potential problem. The O-ring and center rubber seal needs lubricating but not nearly to the extent pictured by the original author.
