| Premium Membership | |
| | | DIY and Tech discussion discussion of the DIY and Tech articles go here. |  | |
06-22-2008, 10:19 AM
eBay Motors
#11 (permalink)
| | Senior Member
| Good write up! Nice pics! While I my self, like psyco66, use diesel to lube the seals. Its the fuel FILTER so if any of the grease comes off it ends up in the filter. Not busting your bubble. To each his own! My question is, however, is that the snap-on WIF sensor wrench or if some other brand? Where can i get one of my own? I have boogered the snot out of my sensor with an adjustable because i was way to lazy to find the right tool!
__________________ 05' LLY CC/SB, PPE Standard, MBRP SS 4", BD Power Manifold, Autometer Phantom 2 Pyro and Boost, Kennedy fingered n plugged, cat grew legs, Belltech 1/3 drop, Michelin LTX M/S 265/75/16, 22 HWY/18 CITY.
Rock it till it sounds expensive!
Dont argue with a moron in public....Others may be confused on whos who. |
| Advertisement
07-02-2008, 02:34 PM
eBay Motors
#12 (permalink)
| | Senior Member
Join Date: Feb 2008 Location: Alberta CANADA, and proud of it!
| Personally I like the idea of using Teflon tape on any threaded fitting. I find it ensures a perfect seal with less torque required for the same result.
Nice catch regarding the yellow vs. white tape. I'll have to keep that in mind. Unlike the grease controversy, I think the tape is a no brainer.
Nice write-up.
Thanks!
__________________ 2007 LBZ 2500HD LT2 CC SB 4x4 Red
Leer canopy, Aries Oval step bars, everything else stock.
Love this truck....HATE the fuel economy  yea yea, I know it's a truck, and YES I want the same mpg as a Civic |
07-05-2008, 08:02 PM
eBay Motors
#13 (permalink)
| | Junior Member
| I ended up getting the same wrench off our Matco guy for $8.00.
__________________ 04 GMC LB7 Crew
Edge Juice w/attitude
Magnaflow exhaust |
07-05-2008, 08:32 PM
eBay Motors
#14 (permalink)
| | BRAIN SURGEON !!!haha
Join Date: Mar 2008 Location: Louisiana,when they let me stay
| Why fix if not broke???  grease or teflon were not intended,the o-ring is the seal,o-rings are really good at sealing hydraulic components,they can hold insane amounts of pressure!!.The plastic and o-ring set up do not require an insane amount of tightening,  jus snug.I would hate to replace fuel system components knowing I put something there that didn't need to be..JMHO
__________________  There she is<<
2006 GMC 2500HD4x4 sb cc LBZ!!!  52k
MODS/Full straight pipe,res mod,SC Fpaq tuner,285/75/16's
Additional gray Berber carpet on floorboards/courtesy of a customer whose home we just built!!!!FREE
2002 GMC 1500 2wd x-cab-sb 5.3l.
1987 89,000k 305H.O. 700-r4[pearl white/red striped]
1978 Malibu[2dr]350c.i./350hp TH-350 trans/jus a lil quick!!!
WORK RIG 2007 YukonXL GPS monitored  for speed,braking,accel,and 5 mile radius from home..oh well |
07-06-2008, 06:04 AM
eBay Motors
#15 (permalink)
| | DuramaxForum Fanatic
| that's correct. putting tape on a non-tapered thread with o-ring seal, is like wearing water proof boots in the dessert. |
07-06-2008, 08:13 AM
eBay Motors
#16 (permalink)
| | DuramaxForum Veteran
| When I install a filter I try to just put enough pressure on it so it will seal. IMO it makes it easier to get off.I do not condone the use of teflon but with any fuel system you are looking at the possibility of getting debris from the tape into your fuel injectors. If you insist on using the tape then make sure it does not extend past the end of the male threads.As far as type of tape I do not think it really matters because the fuel filter will not be on there long enough to be an issue.
__________________ 06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE |
07-07-2008, 08:40 PM
eBay Motors
#17 (permalink)
| | Member
| I was able to find all the parts except that special WIF sensor wrench. Any leads on getting that tool online... I tried a few autoparts stores with no success...May just have to give it a go with an adjustible wrench i guess? |
07-07-2008, 08:47 PM
eBay Motors
#18 (permalink)
| I don't have the tool,and never had a prob,channel locks,or a big adjustable will do well,it does not have to be real tight,I only put mine hand tight with a ol rag,and never had it leak.The o-rings do pretty well
09-10-2008, 12:55 PM
eBay Motors
#19 (permalink)
| | Junior Member
| Can anyone tell me where I acn buy the WIF sensor wrench. Do any of the chain parts stores sell them?
__________________ 2007.5 Duramax-2500, LMM, crew cab, 4x4, drk blue |
09-10-2008, 02:04 PM
eBay Motors
#20 (permalink)
| | Catch Me If You Can!
__________________ KYLE
| Advertisement
