Old 08-03-2008, 07:12 PM   eBay Motors  #31 (permalink)
psyco66's Avatar
Originally Posted by Tow Master View Post
Hey psyco, After running that for a few weeks is your filter on the bottom of you hose all black and covered in oil/soot?
No it is not. It has been like that for 6 monthes and it is still pretty clean.
John
EFI LIVE with McRat RACE tune, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me.
NO TALKING JUST LINE IT UP
psyco66 is offline   Reply With Quote
Old 08-09-2008, 06:19 PM   eBay Motors  #32 (permalink)
psyco66, why did u rought the pipes all the way back to the fuel tank?? thats alot of hoes. im sure there are places to zip tie in the engine compartment. like next to the front diff breather pipe.
2005 gmc 2500 LLY crew cab, airaid intake, 5" magnaflow exhaust cat back, no programer yet. pleasure vehicle 12.7mpg
cloudgmc is offline   Reply With Quote
Old 08-22-2008, 01:07 AM   eBay Motors  #33 (permalink)
Originally Posted by psyco66 View Post
Put a lock nut on the test plug and you are good to go. I hate the way it looks when you pop the hood and it is missing the resinotor box. Looks like sh it in my opionon. I like the stock look. If there is a lock nut on the plug it can not back off.
I got a red "oatey" brand cap from Lowes($3.00) and I was able to put the box back over it. I mean correct me if Im wrong, but if its plugged it shouldn't matter what comes after the plug right?
2004.5 Black GMC 2500 LLY CC 4wd
Cognito Control Arms and torsion bar keys
Cognito Pitman and Idler System 2 inch rear blocks
Bilstein Shocks 315/75R16 BFG KM2's
Bullydog RFI-MBRP 4" Turbo Back Exhaust
Weatherguard Tool Box-Westin Step Bars PPE Standard
Warn Transformer,Black, Warn 12000 lb. winch
Warn 210 dual beam lights. KC Hilites backup lights
2-Rockford Fosgate P3 10s. Punch 360 Amp.Line X Bed Liner
rolltideroll is offline   Reply With Quote
Old 08-22-2008, 10:32 AM   eBay Motors  #34 (permalink)
bigdaddydiesel's Avatar
Anyone done this on an LB7? I have seen two diff opinions on whether it needs it, but when I look at mine, I do not see the same set up, the intake "Tube" leading to the turbo is in the way, Does anyone have a picture of where it should be on mine? If at all? I do not see it... But I also do not have the Resonater, it came off when I put the K&N intake on, it replaced the entire tube, and the resonater came off with the factory tube...
Take a Look at what I am seeing instead...
Chris Kelley is always crying about sumthin Does not like the new format one bit, please change it back.
'03 GMC 2500HD 4x4 extcb sb sle
AMSOIL Direct Jobber ZO # 1678239
Toll Free (888) 563-5143
email
Become A Dealer
Online Catalog
Old 09-15-2008, 06:40 AM   eBay Motors  #35 (permalink)
Did my plug and reroute last night. I actually mounted the filter for the PVC reroute inside the resonator box then remounted it so you cannot tell anything has been removed or plugged until you remove the resonator box.
Finished with reroute and plug
Filter attachment on bottom of resonator box
All Finished
Yamapro is offline   Reply With Quote
Old 09-15-2008, 05:20 PM   eBay Motors  #36 (permalink)
Shhhh Its Hibernating
Tow Master's Avatar
Thanks for the pics!!
I saw the red plug sticking out in your pictures and was scratching my head thinking.. What the hell is that?! Then I read your description.
Did you drill a hole so the resinator box can breath with the PVC air going into it?
Jason
So, I think I'm going to get a stack..... Stacks are cool..... No Im just getting one..... Oh.. Well just don't put it on the gay side..... Wait what??
Old 09-15-2008, 06:29 PM   eBay Motors  #37 (permalink)
Not at first, but after a couple of miles I realized it did need a ventilation hole. Thanks for the input. By the way my filter constantly puffs a light mist of smoke is that normal?
Old 09-16-2008, 05:35 AM   eBay Motors  #38 (permalink)
Bump, light smoke from pvc reroute is that normal? Just barely a mist but I noticed it and became worried.
Old 09-27-2008, 09:07 AM   eBay Motors  #39 (permalink)
just oil vapors nothing to be worried about
07 Gmc 2500 cc/sb 4x4 lbz 5" exhaust,EFI Live,airaid intake,Snow Stage 3 Meth Inj. egr blocker, resonator mod, PPE Hot programmer, ATS stage 3 tranny with 5 star TC. Airdog 150 , stainless tierod sleeves
4" Rancho lift w/ 33" Nitto Terra Grapplers on 18" Helo Maxx 8's
Whoever said, "It's not whether you win or lose that counts", probably lost.
dirtyD is offline   Reply With Quote
Old 10-14-2008, 07:44 PM   eBay Motors  #40 (permalink)
I have an 02 LB7 and was wondering if it even has a resignator to plug?
Mack Attack is offline   Reply With Quote
