I did a re-route on a 6.5T chevy that looked similar years back and it made the engine drink oil like crazy til I changed it back. How bout the d-max does it change oil comsumption?I know most diesel's have a tube out of the valve cover then vented under the engine.
__________________ 2005 LLY CC/SB 4x4/Allison, PPE Xcelerator, MBRP 4" exhaust, AEM workhorse intake, EGR blocker plate,Autometer pyro and boost guages
Thank you for the fast post!!! Anyone else know if the LB7 has a PVC. How much for total parts.
the lb7 duramax for your year of truck does not have a pcv system it only has a crankcase breather system instead of crankcase fumes bieng sucked into the turbo it simplly has a baffle in each valve cover that is connected to an open breather hose that runs down the side of your block.
2002 Crewcab short box 3/4 tonHD lb7 W/Allison stock, ATS DIESEL E-POWER programmer, 5" Jeg's Subway tunnel exhaust straight piped, cranked up torsion bars. PPE pyro and boost gauges havnt installed yet. air dog 150 lift pump in future installed a fass 150/150 and was impressed with results
how do i get back in to change or add to the sig. cant seem to find a way to get back to do it and did not add anything when i first came into this site, and i do enjoy the site, thanks.
test test test
__________________ 2006 Black GMC crew cab LBZ. w/Rhino liner and Truxport bed cover, 4" turbo back exhust.
good write up gona do this this weekend. i used a rubber cap that goes on the outside to remove resonator and titens with a hose clamp so i dont have a steel bold haning over my turbo inlet. wear do u get a filter for the pvc like that, would a catch can like on a turbo car be better? thanks for the info.
__________________ 2007 gmc 2500hd k&n cold air intake, 5'' turbo back exhaust no mufflers, ppe boost controler and edge juce with attitude.
__________________ John
EFI LIVE with McRat RACE tune, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me. NO TALKING JUST LINE IT UP
Ufreak,
Where did you find a cap for the resonator? Is it heat proof? I would rather have a cap also. Let me know where to look for one or what they are called. Thanks...
__________________ 2005 GMC Crew Cab SLT 4X4
4" MBRP turbo back
Diablo Sport Predator/EGR Plate
BD Exhaust Manifold
AutoMeter UltraLiteII Pyro Gauge
Induction Overhaul Kit by "Killer Bee" with
True CAI by "KillerBee" THANK YOU!!! Michael...
It's called a " 2 inch test plug " sold at oreilly and napa stores and most any auto parts store should have them. BTW thanks again for the info psycho.
