| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | DIY and Tech discussion discussion of the DIY and Tech articles go here. |  | |
06-24-2008, 09:20 PM
eBay Motors
#21 (permalink)
| | Senior Member
| Thanks jpat. I have the test plug now but I think I would feel alittle better with the jim cap. When people say "if something could go wrong it probably will" they are talking about "me".
__________________ bob213
2005 GMC Crew Cab SLT 4X4
4" MBRP turbo back
Kennedey air box mod. (ala Hook'em Horns mod)
Diablo Sport Predator/EGR Blocked
BD Exhaust Manifold/PCV Reroute
AutoMeter UltraLiteII Pyro Gauge
Induction Overhaul Kit by "Killer Bee" |
| Advertisement
06-24-2008, 09:33 PM
eBay Motors
#22 (permalink)
| | DuramaxForum Veteran
| Put a lock nut on the test plug and you are good to go. I hate the way it looks when you pop the hood and it is missing the resinotor box. Looks like sh it in my opionon. I like the stock look. If there is a lock nut on the plug it can not back off.
__________________ John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me. NO TALKING JUST LINE IT UP |
06-26-2008, 07:16 PM
eBay Motors
#23 (permalink)
| | Junior Member
| i got a cap from the local pluming store, its not heat resistant and may not last as long as a test plug. but it just looks better and makes me feel safer. a lock nut on a test plug is just as safe just dont look as clean.
__________________ 2007 gmc 2500hd k&n cold air intake, 5'' turbo back exhaust no mufflers, ppe boost controler and edge juce with attitude. |
07-24-2008, 06:45 PM
eBay Motors
#24 (permalink)
| | Junior Member
| what kind of gain would i get out this mod on my 2004.5 silverado duramax lly 4x4?? and if i plan on getting a new turbo, will this mod still be beneficial?
__________________ 2004.5 LLY Silverado Duramax CC/SB 4x4 Black on Black
Performance: Banks Big Hoss Bundle with PDA tuner, Superchips Tuner, SoCal Diesel Fluid Damper, Flex-A-Lite Dual 15" Electric Fans, BD Full Bore Manifold, AirDog Lift Pump System
Appearance: 2006 Escalade Front Clip, Full Custom Black Suede, Fiberglass & Black Ostrich Interior, '99 Deville LED Taillights, Fully Shaved, Bodydrop & Bags In Progress.... |
07-24-2008, 07:58 PM
eBay Motors
#25 (permalink)
| | BLOWIN SMOKE 24/7!
Join Date: Mar 2008 Location: Louisiana,60 miles from Gulf!!
| No perf gain at all,the resonator is there to quiet the turbo whine,shame on GM
__________________ 2006 GMC 2500HD4x4 sb cc LBZ!!!  52k
2002 GMC 1500 2wd x-cab-sb 5.3l.. Wife drives
1987 89,000k 305H.O. 700-r4
1978 Malibu[2dr]350/350hp TH-350 trans
Mods w/LBZ... Full straight piped [no cat,no muff!!]
Superchip Flaspq,res mod/,285M/T tires
: Edge GONE,Bullydog SOLD,thank God!!EFI soooooonnnn!!  [SIGPIC] |
07-24-2008, 11:10 PM
eBay Motors
#26 (permalink)
| Quote:
Originally Posted by DragginDMAX what kind of gain would i get out this mod on my 2004.5 silverado duramax lly 4x4?? and if i plan on getting a new turbo, will this mod still be beneficial? | There is no performance gain. But it keeps oil from getting sucked into the turbo and filling the intercooler. It is just a safety mod.
07-30-2008, 08:56 AM
eBay Motors
#27 (permalink)
| | Senior Member
| Thanks! Going to install this weekend.
__________________  [b]08 Chevy Silverado 2500HD Crew 4x4
6" Fabtech Lift, Pro Comp 35" Tires Extreme A/T & wheels
ATS Extreme Trans w/CoPilot
Quadzilla Stealth 2
4" Turbo Back Silverline System
BD-Performance Exhaust Manifold
Kennedy Diesel Air box Mod & Resonator plug
6k/8k HID Headlight Upgrade |
08-02-2008, 12:33 PM
eBay Motors
#28 (permalink)
| | Senior Member
| All installed, the LMM is a different type of plumbing it uses hard plastic tubes with no room or flex to hook it up like previouse D-Maxx's with rubber lines.
Quadzilla Stealth 2
08-02-2008, 11:26 PM
eBay Motors
#29 (permalink)
| | Super Man Moderator
| Hey psyco, After running that for a few weeks is your filter on the bottom of you hose all black and covered in oil/soot? Quote:
Originally Posted by PinkoDiesel All installed, the LMM is a different type of plumbing it uses hard plastic tubes with no room or flex to hook it up like previouse D-Maxx's with rubber lines. | Hey I like your install! What kind of black hose did you use?
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 265/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
08-03-2008, 09:23 AM
eBay Motors
#30 (permalink)
| | Senior Member
| 1' - 5/8" Heater Hose (Shucks Auto)
1' - 3/8" Fuel Hose (Shucks Auto) or more depending on filter location Keep it high that T-Connector to keep it from getting oil soaked.
1" Bar Stool Leg End Cap (Ace Hardware)
5/8" to 5/8" T-Connection with 3/8" out to the Breather (Shucks Auto)
3/8" Breather Filter for Import (Shucks Auto)
Hose Clamps for 5/8" (On Breather line coming from heads) and 3/8" if you like the T-Connector is a very tight fix and since it only allows air into the crank case there is no pressure.
Quadzilla Stealth 2
| Advertisement
