Old 10-19-2008, 05:47 PM   eBay Motors   #21 (permalink)
BigRedChevy
Super Moderator
BigRedChevy's Avatar
I will be doing mine soon. I hope that i can tell a difference in the steering.
KYLE
2010 Camaro SS LS3 426 HP
Old 10-19-2008, 06:08 PM   eBay Motors   #22 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Cool
Ya'll 'er Hope the word gets out to save some members from Hydro-Boost woes.
Gives a new feeling to an old truck's feel.
Old 10-19-2008, 06:11 PM   eBay Motors   #23 (permalink)
BigRedChevy
Super Moderator
Well i hope so. I have a new hydro boost unit, thanks to warranty, and i don't want to have to do another one.
KYLE
Old 10-19-2008, 06:24 PM   eBay Motors   #24 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Replacement's easy, just hard on the wallet for $400.
Dealer Warranty? I would think they would flush when unit was replaced, then again, who knows.
Old 10-19-2008, 06:28 PM   eBay Motors   #25 (permalink)
BigRedChevy
Super Moderator
They was supposed to flush it, but i don't really trust everything they say. They are the ones that told me i have no coolant loss issues but i found a leak on my passenger side rear corner of the head gasket the other day.
KYLE
Old 10-19-2008, 06:36 PM   eBay Motors   #26 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
I saw your post on the HG and it got me to thinking...you may have noticed a post I had for a 'Massive coolant leak'. In tracing this leak I had coolant in the areas you have noticed, just to a MUCH larger degree.
Have you inspected this hose that blew on me?
Massive Coolant Leak
Old 10-19-2008, 06:38 PM   eBay Motors   #27 (permalink)
BigRedChevy
Super Moderator
i haven't inspected that hose, but there is no coolant above that area. It all starts at HG and runs down from there. I will inspect that hose and hopefully that will be the problem.
KYLE
Old 10-20-2008, 08:43 AM   eBay Motors   #28 (permalink)
scott111
The Power Steering/Hydro Boost flush was very well done!
I have a leak between HB and Master Cylinder. I'm thinking about getting a seal kit and rebuilding instead of replacing the whole unit. Anyone have a write up with pics on doing this? Info is much appreciated.
TEXAS!! FIGHT!!!
2006 2500HD 6.6L Duramax
scott111 is offline   Reply With Quote
Old 10-20-2008, 09:44 AM   eBay Motors   #29 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
TEXAS!! FIGHT!!!
I haven't even found a rebuild kit available. It may not be worth your time, as here is a $ource for only
OUR PRICE: $274.61
GM LIST: $527.91
GM PART # 15854059
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM Parts Direct: Your direct source for Genuine GM Parts
Don't wait too long, that fluid will eat off all of the undercarriage coatings that it comes in contact with. :cool
Old 10-20-2008, 11:06 AM   eBay Motors   #30 (permalink)
DuramaxOnTheBrain
DuramaxOnTheBrain's Avatar
Originally Posted by 1LoudDuramax View Post
So this made a big difference for you? Hmmm i will have to try this out. . . How long did it take you?
Sorry I just now saw this. My email notification doesn't always work...? Yes this makes a huge difference in the feeling of the steering. It was very easy to follow the steps and it only took me less that 30 minutes. I would be be prepared with 4 quarts and maybe a little longer on the fuel hose, maybe 8 feet (longer if you sit up high with a lift or bigger tires. Just FYI I also changed both differentials, transfer case, transmission, oil and filter, fuel filter and lubed the 11 lube points on the front end.
Brian
PPE Standard level 2
Kodiak mouthpiece
Truxedo Duece Tonneau
06 style leveled towing mirrors, 285 75 R16 BFG AT KO
BUY FROM MPF!!!!!
DuramaxOnTheBrain is offline   Reply With Quote
