Old 10-20-2008, 11:31 AM   eBay Motors   #31 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Originally Posted by DuramaxOnTheBrain View Post
Sorry I just now saw this. My email notification doesn't always work...?
I too have been getting notifications that are 36+ hours old.
Old 10-20-2008, 12:24 PM   eBay Motors   #32 (permalink)
DuramaxOnTheBrain
DuramaxOnTheBrain's Avatar
That's a little too slow huh?
Brian
PPE Standard level 2
Kodiak mouthpiece
Truxedo Duece Tonneau
06 style leveled towing mirrors, 285 75 R16 BFG AT KO
BUY FROM MPF!!!!!
DuramaxOnTheBrain is offline   Reply With Quote
Old 10-22-2008, 02:06 PM   eBay Motors   #33 (permalink)
06farmtrk
06farmtrk's Avatar
Hookem,I just flushed my hb unit this morning and used the Dec VI fluid. I tow pretty heavy and was wondering if you noticed if it lasted longer than reg ps fluid.
06 cc lb 4x4 lbz
mbrp 4" turbo back
PPE Standard
cognito upper a arms
AFE intake
B&W hitch
air bags
blocked and fingered
06farmtrk is offline   Reply With Quote
Old 10-22-2008, 02:50 PM   eBay Motors   #34 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Yes, it has held up better. I'm going to try a switch to syn PS fluid as a member sourced NAPA as stocking a Valvoline synPS fluid. Just called and they're going to order it, be here tomorrow. $4 something instead of $6 something for DEX-VI.
Rumored also that GM parts has one for a SAAB exclusive use, but that's probably mas Dinero$.
Old 10-22-2008, 03:42 PM   eBay Motors   #35 (permalink)
06farmtrk
06farmtrk's Avatar
Ok. Let me know what you think of it. Do you believe it will be a little better for the HB unit versus the DEX-VI?
06 cc lb 4x4 lbz
mbrp 4" turbo back
PPE Standard
AFE intake
B&W hitch
air bags
Old 10-22-2008, 03:44 PM   eBay Motors   #36 (permalink)
scott111
Have any of you changed the HB yourself? If so, is there a gasket that came with the part that goes between HB and MasterCylinder? Or any other gaskets I will need?
#1 Texas Longhorns!!!
2006 2500HD 6.6L Duramax
scott111 is offline   Reply With Quote
Old 10-22-2008, 06:31 PM   eBay Motors   #37 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Well, that was a no go. I couldn't find the product on the Valvoline site any longer. Come to find out they have a new part number in place of the old for SynPower, which in reality is just plain PS fluid. It's been discontinued. So, the search is still on. Some had suggested the product for SAABs in a green can, but this is NOT a synthetic fluid.
Royal purple is available for just under $5 for 12oz., not in my price range.
Old 10-22-2008, 06:51 PM   eBay Motors   #38 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
No. Simple stuff, requiring about 30 minutes. Remove the two nuts from the studs connecting to the Master Cylinder, and move forward out of your way. DO NOT remove any brake lines or open the brake system in any way.
Remove the threaded couplings for the high-pressure lines and remove the clamped-on low pressure return line.
On the inside, remove the keeper connecting the push rod to the brake pedal. Remove the 4 nuts from the studs on the HB unit, I recommend a boxed end swivel head ratchet wrench.
Pull the unit forward to remove, and then work in reverse to install the new unit.
Hook up the lines, start the motor and cycle through as described in the flush instructions by moving the wheel left and right while depressing the brake pedal. The unit is self-priming, so kill the engine, and check your PS fluid levels to add back what the new unit displaced in fluid, and you’re good to go.
Old 10-22-2008, 07:23 PM   eBay Motors   #39 (permalink)
scott111
Cool, Thanks.
Just one dumb question so I am clear. Is it supposed to be dry where the HB and MasterCylinder connect (no fluid)? Becuase that seems to be the place it is leaking from but I could be wrong about that. I was wondering about a gasket becuase I was under the impression that there was fluid under pressure at that connection.
Old 10-22-2008, 07:54 PM   eBay Motors   #40 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Not dumb, just a logical conclusion, viewing two units joined together.
Here is a pic, (I like pics )
Recessed in the unit body at that connection is the seal for the piston rod, which is worn, leaking and seeping through that connection.
