Old 06-02-2009, 12:41 PM   eBay Motors   #71 (permalink)
Angel of Death
Burns oil
Angel of Death's Avatar
Replacing the fluid in the PS pump reservoir does nothing to address the burnt fluid in the HB unit, IMO. Similar to having new fluid in the MC and not flushing the lines to the calipers.
Taking a 1/2 qt out the top, replacing with new, running it, and the taking another black 1/2 quart leads me to believe the old fluid in the HB unit and lines is making it's way back to res.
Angel of Death is offline   Reply With Quote
Old 06-02-2009, 12:48 PM   eBay Motors   #72 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Originally Posted by AlisoBob View Post
Brake fluid is static... it dosent circulate.
Power steering / Hydro Boost fluid is dynamic... it does.
Totally different concepts.
To a degree, but the fluid only moves in the system when activated, as in brake action or steering. But the fluid doesn't cycle through like a transmission does.
You're seeing the effects from only part of the system. Once you're satisfied you have clean fluid in the reservoir, pull the return line from the HB unit to see the rest of the fluid that's still burnt and black.
Old 06-02-2009, 01:32 PM   eBay Motors   #73 (permalink)
Angel of Death
Burns oil
I pumped the brakes while turning lock to lock then exhausted the accumulator with the engine off. Wouldn't that return line returning to the res in effect do the same as removing it?
Old 06-02-2009, 01:47 PM   eBay Motors   #74 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
I would think so, I missed the note of brake action earlier. Aren't you always mixing though, instead of draining the old at the bottom end while continually adding new at the top?
On Edit:
I did a comparison (Contractor's truck) after the Dealer had done a flush (through the PS reservoir) because it didn't seem right. And comparing the fluid at the pump versus a sample from the HB unit revealed a difference in color.
It's kinda like the trans fluid...flush whole or change just part, either is better than nothing at all!
Old 06-02-2009, 02:08 PM   eBay Motors   #75 (permalink)
palposity
palposity's Avatar
I have to say I have tried this service exactly as stated at the beginning of this thread and it was sooooo easy I can't think of another way that would be easier. I was very happy with the results.
2001 Silverado CCSB 129K Miles
bigdaddydiesel for all your Synthetic fluid needs
palposity is offline   Reply With Quote
Old 06-02-2009, 02:43 PM   eBay Motors   #76 (permalink)
Angel of Death
Burns oil
I probably didn't mention it, I'm as smart as I am handsome.
Old 06-02-2009, 03:11 PM   eBay Motors   #77 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
No, you did say so. Where my page splits the line, I missed it.
Old 06-27-2009, 11:43 PM   eBay Motors   #78 (permalink)
mojo0107
Timeless Perfection!
mojo0107's Avatar
CAUTION: in the picture below, you’ll see the curved metal brace coming from the cowl. I STRONGLY recommend you place a rag, towel, blanket, or some kind of cushion here.
I took the libertty of fixing this pic...Wasn't sure what you were talking about, BUT NOW I KNOW!
I did find out that the Gal. is the only way to go to get it good and clean.
Matt
2005 Chevy 3500 4x4 SLT Crew Cab, L O N G BED! Leather, Integrated DVD Player,"you know, for the kids!" Banks CAI, PPE ECON stage 2 Installed by BigRedChevy; MBRP 4" SS. Dead CAT Kept the MUFF, Modded turbo mouthpiece
RESONATOR PLUG,EGR Blocker Plate Putco Boss Barz Fat Mud Flaps
"Wake up AMEARICA!"
mojo0107 is offline   Reply With Quote
Old 06-28-2009, 09:03 AM   eBay Motors   #79 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Ouch!
Can't sell 'er now, you've got yer Blood AND sweat in it. I'm headed out right now to run a few qts thru mine, 15k miles and I've got the signs when backing, turning and braking.
Old 06-28-2009, 11:48 AM   eBay Motors   #80 (permalink)
AlisoBob
It absouletly circulates...
AlisoBob is offline   Reply With Quote
