efi and bully dog - Page 5 - Chevy and GMC Duramax Diesel Forum
Old 01-14-2013, 11:48 AM   eBay Motors  #41 (permalink)
To Hotdogstand- So would you say it would be safe for a 120 HP tune with EFI Live? And also with adding that much HP can the head studs handle it? Thanks for the information man!
Dbrad08 is offline   Reply With Quote
Old 01-14-2013, 12:07 PM   eBay Motors  #42 (permalink)
Some Newfie with a dmax
Brennan's Avatar
Originally Posted by Dbrad08 View Post
Ok guys im new to the game and need some info... I have a 2006 Dmax LBZ engine with stock turbo and transmission i have a high air flow kit and dual exhaust 4 inch from the turbo out and a 6 inch lift with 35's and currently have the bullydog triple dog. I wanna know how much HP i would gain if i went with EFI live and since everyting is stock (turbo, engine, and transmisson) is it safe?
What's involved with a "high air flow kit"? It's not always about hp numbers. A good efi tune will give you smoother and cleaner power with decent egts and little smoke which means efficiency.
06 lly,
Black,
Levelled,
Efi by rob,
5"
Etc.
Brennan is offline   Reply With Quote
Old 01-14-2013, 06:28 PM   eBay Motors  #43 (permalink)
Hotdogstand's Avatar
A 120 tune from a good EFI live tuner would most likely be fine on your stock trans, I've run worse on mine and she's still holding up *knocks on wood*. The stock bottom end is good for a lot more power than you'll be making with a stock turbo/trans. These aren't Ford's, either, you shouldn't need to upgrade head studs any time soon, but if you're taking the heads off for any reason, you may as well do It while you're in there.
2003 Chevy 2500HD D/A ECSB 206K
EFI Live, AD 150, Kryptonite tie-rods, MBRP 3" downpipe, MBRP 4" turbo back, batmowheel & BD wastegate, 33" BF Goodrich A/T KOs on H2s
Goals: Built trans and 4" lift, and maybe something about this turbo (again)
Hotdogstand is offline   Reply With Quote
Old 01-14-2013, 07:49 PM   eBay Motors  #44 (permalink)
bstanton's Avatar
I was curious if i could use a triple dog gt as a DSP5 like the edge insight guys do?
11' CC/SB LTZ LML
Stock for now...
bstanton is offline   Reply With Quote
