| EFI Live Place for your EFI questions |
| I'm That Guy... ![]() Join Date: Aug 2010 Location: Gilbert, AZ
| Flash your DSP5 tune on the ECM.
__________________ Tony Non Vendor contact information, URLs and/or links are NOT allowed in signatures or on forum! My opinion is not the opinion of Duramax Forum, Auto Forums, Auto Guide, or other Duramax Forum staff members! CLICK TO READ: FORUM RULES AND DF STAFF! Thank you Rob Coddens (Idaho Rob), Dustin @ ATP, Scott @ SDP, Kory Willis, and Mike L. for all of your help! Shhh... I sold my Dmax and I own a gasser now, don't tell anyone!!! I'll buy another Dmax soon, probably LLY or LBZ. |
| Junior Member Join Date: Apr 2012
| It was already done , you think doing it again will help? Will it screw with anything doing it a second time ?
__________________ 2009 dmax lmm ccsb hd2500 AFE 5" turbo back,AFE Bladerunner intercooler,AFE 3" turbo hot pipe, H&S Blackmaxx programmer with ActiveMaxxx software, Snow Performance stage 3 water/meth kit,resonator delete, pcv reroute, airdog 2 200 lift pump, egr delete, dpf delete,ppe race exhaust manifolds and up pipes, b&w gn hitch with companion 5th wheel hitch, SDP twin turbo, 40% over nozzels,efi live tunning Idaho Rob, alligator stage 5 trans kit, built t.c. By Holton |
| | eBay Motors #13 (permalink) |
| DuramaxForum Veteran ![]() Join Date: Jun 2012 Location: Choctaw, OK
| nope flash away!
__________________ My LMM Build Thread 08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves..... |
| Are you doing a full flash? You can flash multiple times, it shouldn't mess anything up. Switch position when you data log says non-dsp or dsp#1?
| | eBay Motors #15 (permalink) |
| Duramax Forum Supporter Join Date: Jan 2012 Location: Montana
| I believe with the LMM that the DSP5 switch will read (using the autocal) DSP5 in position #1 and nonDSP5 in the remaining 4 positions. Is this correct?? Anyway, that is how my DSP5 switch reads in my LMM and my switch is working properly. |
| | eBay Motors #16 (permalink) |
| I don't follow what you're trying to say FAIRCHASE. |
| | eBay Motors #17 (permalink) |
| Data log using the autocal to determine if the DSP5 switch (in LMM) is working, I get DSP5 in position #1 and nonDSP in the remaining 4 positions. I know this is different in the preLMMs which reads DSP #1 ....... DSP#5 when data logging. Am I ?????????Bottom line, my DSP5 switch is working but justing wanting clarification on what each switch postition should read when data logging. |
| | eBay Motors #18 (permalink) |
| You should have... Non-DSP DSP#1 DSP#2 DSP#3 DSP#4 I'm unaware of any issues with the AutoCal that present otherwise, but it's possible as I don't deal with them or own my own AutoCal. |
| | eBay Motors #19 (permalink) |
| What I do have ...... DSP5 nonDSP nonDSP nonDSP nonDSP |
| | eBay Motors #20 (permalink) |
| Mine is the exacte opposite Nondsp Dsp5 Dsp5 Dsp5 Dsp5
