dsp5 help on lmm - Chevy and GMC Duramax Diesel Forum
post #1 of 23 (permalink) Old 04-05-2012, 05:20 PM Thread Starter
dsp5 help on lmm
i got my tunes from rob onto my autocal and hooked up my switch. ive tried and tried i know im in the right slot and im pretty sure the pin is seated cuz i tried getting it out and it dont want to. i dont want to yank on it and pull the wire out of the pin. i grounded inside the cab next to the steering column. i know the ground is good cuz my hardwire kit for my radar was grounded. there. ive used a test light and no power and no luck changing tunes. any help or suggestions would be greatly appreciated. thanks
txmax is offline
post #2 of 23 (permalink) Old 04-05-2012, 05:31 PM
RedMax316's Avatar
Make sure pin clicks in when you think it all the way in push it in more lol I thought mine was all the way in first time but had to push it in more
Sent from my DROIDX
Donnie 08 GMC Sierra 2500HD cc/sb Debadged 5in straight pipe MPI twins 60% Big Dipper nozzels EFI live tuned by Rob at ATP PVC reroute Bank 3in IC pipe PPE Race Vavle & Ported Fuel Rail Fitting CP3 High Flow Feed Line Kit Raptor 150 lift pump built trans by Big Dipper EGR delete with 3in Y-bridge BD manifold Tinted tail lights & 3rd brake light Recon smoked LED cab lights LED tailgate bar Big Rig amber running lights 8K hids lows & driving Fuel Hostage rims Nitto 420's 305/50/20 3in drop shackles traction bars PPE straight centerlink Rareparts tierods Rancho steering stablizer and shocks line X Bed liner billet fuel door
http://www.atptrucks.com/
RedMax316 is offline
post #3 of 23 (permalink) Old 04-05-2012, 05:36 PM Thread Starter
yea man i pushed and pushed with a paperclip and now it dont want to come out
txmax is offline
post #4 of 23 (permalink) Old 04-05-2012, 05:38 PM
ATS Diesel Performance
lb7blksmk's Avatar
Send a message via Yahoo to lb7blksmk
Check the voltage on the switch and make sure it is changing from 1 to 5 volts
David Spidle
03 LB7Auroura 5000 W/ Manifolds & Up-pipes, Synapse 50mm Gate, 40% Over Injectors, Alligator Stg5 Trans, EFI Live
lb7blksmk is offline
post #5 of 23 (permalink) Old 04-05-2012, 05:45 PM Thread Starter
How do I check the voltage. I've been in the record data where it says dsp5#1 and it don't change any tunes
txmax is offline
post #6 of 23 (permalink) Old 04-05-2012, 05:58 PM
I'm That Guy...
TDFDiesel's Avatar
Just to confirm, have you already flashed your tunes?
Tony
Old Trucks: 3 - LLY, 1 - LMM
TDFDiesel is offline
post #7 of 23 (permalink) Old 04-05-2012, 06:03 PM
lb7blksmk's Avatar
you can hook it up through your laptop and conect to your vehicle using the scan tool and check your DSP5 switch voltage or you can check your voltage with a volt meter.
David Spidle
post #8 of 23 (permalink) Old 04-05-2012, 06:17 PM Thread Starter
See I don't have a laptop I had to flash from my desktop
txmax is offline
post #9 of 23 (permalink) Old 04-05-2012, 06:42 PM
I'm That Guy...
TDFDiesel's Avatar
Tony
post #10 of 23 (permalink) Old 11-25-2012, 02:16 PM
dmaxkry's Avatar
This is what mine is doing how did you fix it??
2009 Dmax lmm tunned by Kory
Built trans
Krytonite front end
Twins
dual fuel pumps
Braced
40% overs
most supporting mods
dropped
12.571 sec @ 106.53 mph
thanks to Atp, Alligator, D-max Store, Synthetic Motor Sports, SDP, Lloyds customs
dmaxkry is offline
