Help Losing Boost Presure - Chevy and GMC Duramax Diesel Forum
post #1 of 13 (permalink) Old 06-29-2012, 07:33 AM Thread Starter
I have EFI just installed a week ago. When I build 20psi boost it drops back to 10psi and just about puts me in the wind shield. On top of that, when I put it on level 1 it runs like I am pulling 30k pounds, alot of RPMs and no go. Any idea what it could be? I do have a build trany and few other mods.
parkplug92mx is offline
post #2 of 13 (permalink) Old 06-29-2012, 06:48 PM
I'd start by filling out your signature so we know what truck you have.
Then you'd benefit from pressurizing the intake to 30 psi using shop air and listen for leaks.
MTL_Dmax is offline
post #3 of 13 (permalink) Old 06-29-2012, 08:44 PM Thread Starter
Sorry. LBZ egr delete kit with bigger turbo.
post #4 of 13 (permalink) Old 06-30-2012, 05:15 AM
You may also want to look at the MAP sensor, I've seen it crack and cause issues too.
MTL_Dmax is offline
post #5 of 13 (permalink) Old 06-30-2012, 07:57 AM Thread Starter
I looked and it is not cracked. Thanks
post #6 of 13 (permalink) Old 06-30-2012, 08:16 AM
Its just a worktruck
DMAXchris's Avatar
What turbo is on it?
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
post #7 of 13 (permalink) Old 06-30-2012, 08:52 AM
Thebiggids's Avatar
Who tuned it? Give them a shout
GideonHeyyaa
01 LB7 EC/SB Ally 4x4
DD: 1990 4runner completely stock 4x4 3.slow
2007 Yukon Denali - Hers
Big Thanks To Adrenaline Truck Performance, Alligator Diesel PerformanceSocal Diesel and Lincoln Diesel Specialties
Thebiggids is offline
post #8 of 13 (permalink) Old 06-30-2012, 09:19 AM
rebpdt's Avatar
datalog time
CCSB LB7 4x4
rebpdt is offline
post #9 of 13 (permalink) Old 06-30-2012, 10:02 AM
mxhead6.6's Avatar
mines doing the samething, i found my stock egr leaking, time to delete it! try the soap and water test when the trucks cold.. a bit quicker and easier then pressurizing the whole intake, you'll find it if its a big leak..
2006 silverado 2500hd loaded,blue LED conversion, cobalts, CTS,6'' skyjacker, softride springs
mbrp down pipe, 4'' straight pipe, 7''mbrp stack,
EFI live DSP5
Ignited 8000k low beams, highbeams, fogs.Banks ram air,bushwaker fender flairs,35'' Nitto Mud Grapplers
RBP 18'' 94r's, RBP RX-2 running boards, RBP RX HD Grille,BD turbo gaurd,Airdog2 165,Longhorn Fab Shop trac bars,alpine 7'' double din, 2 Type S's under the rear seat,trainhorn
Tranny and spinny thing to come!
mxhead6.6 is offline
post #10 of 13 (permalink) Old 06-30-2012, 10:14 AM
Originally Posted by rebpdt View Post
datalog time
X2
A good EFI log file would help alot (use Duramax LBZ Imperial PID when logging if you do)
MTL_Dmax is offline
