| EFI Live Place for your EFI questions |
| Senior Member Join Date: Jan 2007 Location: Great Falls, MT
| DSP5 install Getting ready to install my DSP5 switch and load my tunes. Are there any precautions I need to take prior to removing the harness from the ECM, such as disconnecting the batteries or anything else? Also, did everyone else run the wires through the hood release cable? Any other tricks or tidbits I should know before I begin? Thanks for your comments! Sent from my iPhone using AutoGuide.com App
__________________ 2006 GMC Sierra CC SB LBZ, 68,000 and climbing EFI Live, EGR Blocker Blocked... 2008 Chevrolet Suburban 1991 Chevrolet 1500 Step Side 2003 GMC LB7 CC/LB (sold) |
| DF Sponsors ![]() ![]() Join Date: Jul 2010 Location: Union, IL
| Shov, Our ECM Installation page may be of some help to you. We have videos on there that should help guide you through the installation. You can find them here. -Steve
__________________ http://www.duramaxtuner.com Custom Tuning ♠ SPADE Series ♠ Tuned ECM's ♠ Performance Parts Quotes, Questions, Comments - Call us: 815-923-4315 Follow @duramaxtuner Like us Youtube |
| Thanks so much. Got it loaded!
| Senior Member ![]() Join Date: Feb 2011 Location: montrose, MI
| I used ATP videos when I did mine, had a hard time getting the wire thru the main wire rubber boot so I went thru the boot at the steering shaft, P.S. I also ran my boost and pyro thru it also years ago, just have to make sure it does not touch against the shaft. I did not disconnect the batteries. took about 20 minutes total. I put my switch in a hole in the bottom of the dash below the steering wheel, their are holes in the sheet metal all ready their, just have to open it up a little. nobody can see it at this position
__________________ 06, CC, SB, 4X, LBZ, AD2, DP/full exh, blocked, nicktane, tgo,DSP5 from rob, gauges,bagged/compressor, reroute, some other stuff Superglide hitch 2012 Wildcat 344QB |
