| EFI Live Place for your EFI questions |
| DuramaxForum Veteran ![]() Join Date: Jun 2012 Location: Choctaw, OK
| I don't know of a way to check if it's working but if the shop messed up installing the ground wire I would double check their work or bring it back to them and tell them they messed up. If I were you though just check it yourself.
__________________ My LMM Build Thread 08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves..... Last edited by StealthBoogie; 11-25-2012 at 03:11 PM. |
| On my phone but see if this link works: EFI Live DSP Install Instructions
__________________ My LMM Build Thread 08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves..... |
| | eBay Motors #13 (permalink) |
| Junior Member Join Date: Apr 2012
| Thanks stealth ill check it out
__________________ 2009 Dmax lmm ccsb HD2500 AFE 5" turbo back,AFE Bladerunner intercooler,AFE 3" turbo hot pipe, H&S Blackmaxx for gauging with ActiveMaxxx software, Snow Performance stage 3 water/meth kit,resonator delete, pcv reroute, Airdog 2 200 lift pump, egr delete, dpf delete, ppe race exhaust manifolds and up pipes, B&W gn hitch with companion 5th wheel hitch, SDP twin turbo, 40% over nozzles, EFI live tunning by Idaho Rob, Alligator stage 5 trans kit, built t.c. By Holton, Kryptonite stage 3 front end, cognito 60' trac bars, cognito support braces |
| So I checked all the wires they are all good . Now I don't know what to do next ... Do a full reflash????
| | eBay Motors #15 (permalink) |
| Sure, it dont hurt to flash it again
| | eBay Motors #16 (permalink) |
| "THEEPASUCKS"! | You can ground the DSP5 switch under the dash. Here is a diagram for testing the switch voltage.
__________________ 2008 2500HD LTZ EFI LIVE DSP5 + Edge CTS Insight 6" Superlift - 35" Pro Comp's - 18"Mazzi Hulks Amp Research Steps - Billet Grille - PCV Reroute - Diamond Eye Down Pipe - MBRP SS Exhaust - AFE Delete Pipe Cognito Braces - Moog Pitman & Idler Arm - Fabtech HD Tierods Dmaxstore - Duramaxtuner - Madjacksracing - MeyerPerformance - Alligatorperformance - Performancetruckproducts Last edited by WOLFN8TR; 11-25-2012 at 06:46 PM. |
| | eBay Motors #17 (permalink) |
| Duramax Forum Supporter Join Date: Jan 2012 Location: Montana
| Are you sure the DSP5 is not working? Meaning you do not feel any difference in 1-5 while driving? Have you tried using a voltage meter on the switch? I am asking because I thought I had the same issue as you but discovered through ADP (who did the install) that the LMM ECM (using the autocal) will show DSP5 and then non-DSP5 for the next 4 levels. Give ADP a call and ask for David. |
| | eBay Motors #18 (permalink) |
| A good way to determine if the DSP5 switch is working while you are driving is to set the DSP5 switch to a tow setting and push the tow buttom on the shifter. Go find a hill to drive down and as the engine is braking, move the DSP5 switch to another setting and you should feel less engine braking if the switch is indeed working. |
| | eBay Motors #19 (permalink) | |
| Quote:
__________________ 2009 Dmax lmm ccsb HD2500 AFE 5" turbo back,AFE Bladerunner intercooler,AFE 3" turbo hot pipe, H&S Blackmaxx for gauging with ActiveMaxxx software, Snow Performance stage 3 water/meth kit,resonator delete, pcv reroute, Airdog 2 200 lift pump, egr delete, dpf delete, ppe race exhaust manifolds and up pipes, B&W gn hitch with companion 5th wheel hitch, SDP twin turbo, 40% over nozzles, EFI live tunning by Idaho Rob, Alligator stage 5 trans kit, built t.c. By Holton, Kryptonite stage 3 front end, cognito 60' trac bars, cognito support braces | |
| | eBay Motors #20 (permalink) |
| "THEEPASUCKS"! | PIN install position.
__________________ 2008 2500HD LTZ EFI LIVE DSP5 + Edge CTS Insight 6" Superlift - 35" Pro Comp's - 18"Mazzi Hulks Amp Research Steps - Billet Grille - PCV Reroute - Diamond Eye Down Pipe - MBRP SS Exhaust - AFE Delete Pipe Cognito Braces - Moog Pitman & Idler Arm - Fabtech HD Tierods Dmaxstore - Duramaxtuner - Madjacksracing - MeyerPerformance - Alligatorperformance - Performancetruckproducts |
