| EFI Live Place for your EFI questions |
| Junior Member Join Date: Apr 2012
| Dsp5 switch not grounded do I need to do a full flash on the ECM I found the dsp5 switch was not grounded I was wondering if I have to do a full ECM flash again to program the ECM . I was using the autocal to do a system scan and tried to test the dsp switch and nothing happened found the black wire was not clipped in all the way now it says non-dsp and then goes to dsp5 help please
__________________ 2009 dmax lmm ccsb hd2500 AFE 5" turbo back,AFE Bladerunner intercooler,AFE 3" turbo hot pipe, H&S Blackmaxx programmer with ActiveMaxxx software, Snow Performance stage 3 water/meth kit,resonator delete, pcv reroute, airdog 2 200 lift pump, egr delete, dpf delete,ppe race exhaust manifolds and up pipes, b&w gn hitch with companion 5th wheel hitch, SDP twin turbo, 40% over nozzels,efi live tunning Idaho Rob, alligator stage 5 trans kit, built t.c. By Holton |
| DuramaxForum Veteran ![]() Join Date: Jun 2012 Location: Choctaw, OK
| I dont think you have to flash it again. I flashed mine before installing the dsp5 switch and it worked just fine after installing it
__________________ My LMM Build Thread 08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves..... |
| But using the auto cal scan it just showes non-dsp5 and then flips to dsp5 ???
| DuramaxForum Enthusiast Join Date: Jun 2011 Location: Bellingham, Wa
| Dont need to flash again. Problems with the switch/connections
__________________ Gideon ![]() 01 LB7 EC/SB Ally 4x4 shop ornament DD: 1990 4runner completely stock 4x4 3.slow Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel |
| What do I check
| did you make sure your red wire clicked(hear it) into to the correct spot? Did you follow any DIY on how to do it?
| No I had the shop install it initially but was checking things with the scan on the auto cal and that's how I found the ground wire. As for the correct spots I hope there right thats where the shop guys put them
| I heard the black wire click when I put it in
| Stealthboogie how can I tell if the dsp switch is not working ?? do I just replace it??
| DuramaxForum Veteran ![]() Join Date: Mar 2012 Location: Casper, Wyoming
| Watch one of the how to videos and then look at your connectors, I'll bet it's hooked up wrong. You can also check the resistance between the 2 wires as you select the positions on the switch. I don't recall the actual numbers, but they will all be different
__________________ 2007 CCSB LBZ. ![]() EFI live DSP 5 by Rob @ ATP EGR blocked, PVC reroute AirDog II 165 TransGo Jr/pump rub mod Firestone bags 4" MBRP Edge Insite CTS w/ backcam Cognito W/Bilsteins 69 Camaro S/ST-S/Gas |
