| EFI Live Place for your EFI questions |
| Junior Member Join Date: Dec 2011 Location: Northren, New York
| Auto cal need help Can someone help me out here , How do i program my ecm back to stock ? im having some trouble here.....
__________________ 2006 LBZ Crew cab , 4 "MBPR straight pipe, EFI Live dsp5, ProFab EBR delete pipe with LB7 up pipe , PVC Reroute, Transgo Jr Shift kit., Cooper Discovery ATP 265-75-R16, Rare Parts Tie Rods |
| Im having some major issues here and i cant figure out. when i try to read my ecm i keep getting error codes and the dsp 5 switch says non dsp 5 then just dsp 5 . i had just finished my egr delete and now my truck wont go over 25 mph and wont shift right.. im kinda at a loss and dont under stand whats going on any help is appreciated.
| DuramaxForum Veteran ![]() Join Date: Jun 2012 Location: Choctaw, OK
| Did you get it from efi from Atp? Should of came with good instructions. First, is your keyed turned to the on position?
__________________ My LMM Build Thread 08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves..... |
| yes idk how to go back to stock ..i don't have the instruction and im ecm is unresponsive i don't understand what happened .. but how do i upload my stock tune to the auto cal and put it back on my truck? yes i got it from atp
| Senior Member Join Date: Apr 2011 Location: Corpus Christi, TX
| Call Dustin at ATP.
__________________ Jacob 2008 SLE GMC C/C. 4" mbrp, FTE resonator, EFI from duramaxtuner, blocked and rerouted. CAT filter adapter with Donaldson filter. |
| i dont have a phone or cell service in the garage just internet i tried pm him but never go an answer i guess il have to call him tomorrow.....
| | eBay Motors #7 (permalink) | |
| ATPTRUCKS ![]() Join Date: Sep 2009 Location: Boise, ID
| Quote:
When you pull the stock tune off of the truck with the autocal, that tune has to be emailed to us to save for remote flashing. You can't just turn around and flash it right back in. Call me tomorrow and I'll get you going Sent from my iPhone using AutoGuide.com App
__________________ Dustin im 22 and yes i bought my trucks myself Blackout :06 GMC lbz 4x4 Built motor, SDP twins, exergy Injectors, Self built trans White Thing :07 Chevy lbz 4x4 Caged and built to the hilt ![]() Special thanks to: Mike L, Gtrippin, IdahoRob, SDP, ISSPRO, Yukon, and Cam at AP LIKE US ON FACEBOOK! Adrenaline Truck Performance IDAHO ROB 208.685.1000 | |
| did you copy your stock tune like the intructions said before you flashed the tunes? After you copy them with the auto cal you must connect the auto cal to the computer and open the efi live explorer, then transfer your stock tune to the same folder of your dsp5 tune( if its not already there). For me, I had to have Rob send me my stock tune with it snyced to my auto cal cause I wasnt able to load it back to the autocal Edit: What Dustin said...
| "THEEPASUCKS"! | Sub'd...
__________________ 2008 2500HD LTZ EFI LIVE DSP5 + Edge CTS Insight 6" Superlift - 35" Pro Comp's - 18"Mazzi Hulks Amp Research Steps - Billet Grille - PCV Reroute - Diamond Eye Down Pipe - MBRP SS Exhaust - AFE Delete Pipe Cognito Braces - Moog Pitman & Idler Arm - Fabtech HD Tierods Dmaxstore - Duramaxtuner - Madjacksracing - MeyerPerformance - Alligatorperformance - Performancetruckproducts |
| Yeah i copied it just never emailed .. i keep getting a u0100 and when i try to plug my autocal in and just do a read it says error %0538 im pretty sure. I had the batteries out for a few days but im not really sure how thats relavent .. I was finishing my egr delete and pcv reroute. once pluged back in i had these issues... i will def be calling tomorrow.
