| EFI Live Place for your EFI questions |
| | eBay Motors #81 (permalink) | |
| DuramaxForum Veteran Join Date: Mar 2011 Location: Missouri
| Quote:
__________________ 05 CCSB EFI Live by Kory Willis 76 Dodge Charger SE http://www.duramaxforum.com/forum/91...mber-list.html www.TrollPerformance.com | |
| | eBay Motors #82 (permalink) |
| Duramax Lifetime Supporter ![]() Join Date: Sep 2011 Location: VA beach
| go for it, just please film it
__________________ 07.5 LMM EFI Live by Kory PPEI Banks intake, EGR delete, PCV reroute, Trans Go Jr, 5in turbo back straight pipe, Air Dog 150, PPE rail plug, boost, fuel, and EGT ISSpro gauges. |
| | eBay Motors #83 (permalink) | |
| Senior Member Join Date: Jan 2012 Location: B.C. Canada
| Quote:
__________________ 2008 GMC Dually LMM 6" lift 285/75R17 "E" TOYO M/T Banks intake/DPFdelete with MBRP exhaust PPE Hot Race tuner / TransGo Jr. / Pillar gauges JVC - DVD/Nav system & Back up camera/2500w inverter/ 55w reverse lamps/Amber strobe lights X4 corners front hidden hitch/rear hitch/turn over ball 5th wheel hitch/custom grille DRW # 101 | |
| | eBay Motors #84 (permalink) |
| All In Join Date: Jan 2011 Location: West Texas
| If you're lucky you'll only melt a piston. You might get to see your rods without removing any bolts!
__________________ cc/sb lb7, lowered, cut & delipped, lbz rods, keyed, balanced, ati, so cal flex, studded, +40 nozzles, going 360/480 from SDP |
| | eBay Motors #85 (permalink) |
| Junior Member Join Date: Sep 2012 Location: intermountain west
| That must be part of the special upgrade? Stacked canned tuners plus efi makes inspecting your engine for excessive internal wear easier?
__________________ Currently: 2006 CCSB LBZ ~ 4" exhaust/AFE intake ~ Pyro/Boost on the a-pillar ~ EFI Live w/ dsp 5 ~ CAT fuel filter Politically Correct: A term used for whiny pu**ies that need sh*t sugar coated |
| | eBay Motors #86 (permalink) |
| DuramaxForum Veteran Join Date: May 2011 Location: Columbia, South Carolina
| Damn the OP's first post has already made it on Facebook!
__________________ TYLER LB7 2500 HD LT 6" ZONE, Cognito UCAs, 37" Toyo MTs, 22" Fuel Hostage EFI Live by ATP, Edge Insight CTS, S&B intake, Pro-Fab turbo mouth piece, PPE boost valve, Alligator CAT adapter, 5" Diamond Eye exhaust, 6" MBRB tip |
| | eBay Motors #87 (permalink) |
| Senior Member Join Date: Jun 2009 Location: NW MT in the SNOW
| lulz
__________________ 07.5 GMC Sierra 3500 SRW CCLB- Stock(for now)- 150k Miles Sold-2004.5 LLY CCSB- All the right stuff Sold-2004.5 LLY CCSB- All the right stuff Admin in regards to smoke threads... |
| | eBay Motors #88 (permalink) |
| DuramaxForum Veteran Join Date: Aug 2009 Location: Northern VA
| SO much win!!
__________________ 2003 2500HD LT CCLB, 4" MBRP, Diamond Eye Down Pipe, Ported Intake Horn, S&B Intake, PPE Boost Valve, ADII, Nicktane CAT Adapter, Edge CTS, Cognito UCA, Rare Parts Tie Rods, Bilsteins, Gear Alloy wheels, Hankook RF10 285's, PPE Level 2, All on Mod, DDM 5k Low's & 4300 Fogs, air horn, on board air ![]() http://www.trollperformance.com/ You know you want too |
| | eBay Motors #89 (permalink) |
| Junior Member Join Date: Feb 2012
| I think he dislikes EFI live due to the fact it doesn't smoke a lot. I think what he is asking is "How do I get more smoke?"
__________________ 2010 Dodge Avenger Worst gas mileage Slow Cheap Turd Duramax very soon! |
| | eBay Motors #90 (permalink) |
| Junior Member Join Date: Sep 2008 Location: scottsbluff ne
| The only way to stack chips on a dmax is purchase a smarty (w/smoke tune) install Then edge juice (must me w attitude) install uninstall EFI live...give it to me.... now with having installed and uninstalled these features...you now need to put pickup in 1st gear and got just WOT!!!!!! for at least 10 seconds...this will clean out your rail and get the tuning from previous posted "chips" installed correctly...after this your motor should have a rod waving at you through the block...at this time restart process until something doesnt hit you.........in order for proper timing of the stacked chips you will also need the big "C" in your rear window...I know it sounds stupid but it works!! The moral of this story is give me you EFI hehehehe
__________________ 07.5 lmm CC SB BONE STOCK!!!!......................................... ....for now.... ![]() IM ADDICTED TO WINNING!!!! |
