Office: EFI Live DPF Feature Removal Thread - Page 13 - Chevy and GMC Duramax Diesel Forum
Old 12-11-2012, 04:43 PM   eBay Motors  #121 (permalink)
Needs a S.A.S.
WVRigRat05's Avatar
^^ I wouldnt worry about it, sip on some shine and forget about it like I do
Reger
Black on Black 05' Silverado 2500 HD 4X4 CC/SB, LBY7, LT. 8580 lbs
Built motor/Trans and tuned by Blackout Performance
Engine- LB7 block, keyed crank and cam, LBZ rods, cut LB7 pistons, ATI damper, MA pushrods, MA motor mounts, LML man., new guts in heads, blocked, re-routed, Bills custom intake
Trans- PPE stage V Suncoast 1057 converter
Exhaust- 3" D.E. dp, 4" MBRP, 5" RBP tip
Suspension- Leveling kit buried, 3 rear springs added, Moto Metal 956's, 35's
Steering- Cognito braces, Cognito sway bar links, P/S cooler, straight centerlink, Rare parts tie rods
Interior- Wilson cell amp, Galaxy 73V, Boomer 400 linear, scanner, bluetooth
2011 30' Puma KDBSS
WVRigRat05 is offline   Reply With Quote
Old 12-11-2012, 04:52 PM   eBay Motors  #122 (permalink)
mackyoudip's Avatar
Ermagherd, the ERP an A gonna take muh muffrawr!
sig worthy
Mack: LMM.
mackyoudip is offline   Reply With Quote
Old 12-11-2012, 05:06 PM   eBay Motors  #123 (permalink)
New to me GMC's Avatar
Anyone have any idea when the software changes will take effect? And will these updates and removal of features be for all controllers or just the Dmax controllers? I have a buddy that i helped button up an LS2 swap for a hot rod and he's planning on ditching his LS edit for EFI live. But he's going to need to be able to edit out emissions stuff. Ide like to give him a heads up, but some more details on when the software will change would be nice.
01 GMC 2500hd ecsb Dmax/Alli. 4" exhaust to 5" single stack,EDGE Insight CTS, EFI Live running Nick tunes, Suncoast stage IV, Complete Kryptonite front end with PISK , 305/55/R20 Cooper Zeon's on Rockstars. Eaton E-locker. So cal stage I heads, and a little bit of laughing gas.
07 LMM LTZ CCSB. S475 over stock compounds, 40% over dipper sticks, Suncoast tranny by Freedom Diesel, Air Dog, ATP tuned.
New to me GMC is offline   Reply With Quote
Old 12-11-2012, 05:22 PM   eBay Motors  #124 (permalink)
EFI-Live Tuner
Moonshine's Avatar
Originally Posted by ne-max View Post
Do you guys think that they will go after the proffesional efi tuners next?
I guess they could go after every single person who has used any type of handheld or software to defeat any emissions control.
Anyone one, professional or not, for profit or personal use can and will be treated the same, if you delete it you could be in trouble.
I highly doubt they care, its always going to happen, people will always use software or some other means to alter their vehicle.
Gasser guys are also not exempt if they disable the emissions.
It's all hype and BS if you ask me.
Tony Martino- Ridge Runner Diesel Performance, LLC
V2 - Autocal - Pre-Tuned ECM's available......... www.ridgerunnerdieselperformance.com
RRDP/COTN - EFI-Live Sales
Custom ECM and TCM Tuning for 2001-2010 LB7, LLY, LBZ and LMM trucks, accessories and bundles available thru Creatures of the Night Performance - Henry Webb
Moonshine is offline   Reply With Quote
Old 12-11-2012, 05:24 PM   eBay Motors  #125 (permalink)
anthonyshaw's Avatar
As long add you have an older copy of the software,I would assume you'd be alright. That's what hptuners did, anyway
Sent from my Samsung Galaxy S3 using AutoGuide App
'08 GMC Sierra SLT CCSB LMM
4" MBRP Downpipe-back, EFI-Live V2, DSP5 Switch, Tuning by Idaho-Rob, EGR Block-off
anthonyshaw is offline   Reply With Quote
Old 12-11-2012, 05:32 PM   eBay Motors  #126 (permalink)
What i was getting at is should someone who needs to be able to disable the Evap, EGR etc be purchasing soon before all the new V2s contain software omitting these tables?
Old 12-11-2012, 05:34 PM   eBay Motors  #127 (permalink)
Eh, unless they require the latest version to register, no. Just download 7.5 from their site now and hold onto it
Old 12-11-2012, 05:42 PM   eBay Motors  #128 (permalink)
I'm That Guy...
TDFDiesel's Avatar
I think by making a big deal about all of this we are just perpetuating the image and making a bigger statement to other companies that offer similar products.
TDFDiesel is offline   Reply With Quote
Old 12-11-2012, 05:45 PM   eBay Motors  #129 (permalink)
FC5452's Avatar
You know this could be a Beotch for all on the tuning side as well, normally when one mfg plays kindly with the man, they all do. Not shifting gears here just find all of this highly interesting.
LML with some stuff added
13.1@105
Time to beat: 6DOT6 <<<----Real Soon
FC5452 is offline   Reply With Quote
Old 12-11-2012, 05:49 PM   eBay Motors  #130 (permalink)
boostnlb7's Avatar
sipping shine now ^^^^^
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
