HIGH EGT's lbz - Page 4 - Chevy and GMC Duramax Diesel Forum
Old 01-02-2013, 10:38 PM   eBay Motors  #31 (permalink)
bubblebutt's Avatar
My 2 cents = you've tried a different prob same thing and different tunes same thing, going to say it's not prob or tunes.....
Engine?? high EGT -possible cam timing ??? Restriction in intake or exhaust?? >> just throwing it out there, (I have done more work on gas engines )
2008 GMC Dually LMM
6" lift 285/75R17 "E" TOYO M/T
Banks intake/DPFdelete with MBRP exhaust
PPE Hot Race tuner / TransGo Jr. / Pillar gauges
JVC - DVD/Nav system & Back up camera/2500w inverter/ 55w reverse lamps/Amber strobe lights X4 corners
front hidden hitch/rear hitch/turn over ball 5th wheel hitch/custom grille
DRW # 101
bubblebutt is offline   Reply With Quote
Old 01-02-2013, 10:41 PM   eBay Motors  #32 (permalink)
CRFmxracer's Avatar
i agree, zack is a great guy. i had numerous brain farts getting my dsp5 to work and he stuck with me like a champ until we finally got it working (Still dont know why it wasn't all we did was undo it and redo in a walmart parking lot) x2 on zack becoming a sponsor
1995 Chevy 6.5 w/ 4 inch Diamondeye Turbo Back, KYB Shocks Eagle Alloy 16x8 186s,BFGoodrich A/T 285s 160K and climbing, Voted Most Attractive 6.5Around SOLD
2001 Blue RC/LB 2500HD
4inch Diamondeye straight pipe, 4inch Billscustomintake w/ aem dry filter, PPE Boostvalve, H2s and 33s, Debadged, Leveled, Airdog 165, Autometer Cobalts, Efi-Live with Starlite Diesel Tunes, ProFab Turbo Horn
Wishlist:Tint, smoke running lights, black out valance, billet grill, Blackout Performance trans, S472+injectors, tie rod sleeves
CRFmxracer is offline   Reply With Quote
Old 01-03-2013, 10:45 PM   eBay Motors  #33 (permalink)
Thanks guys for the support and the reccomend at becoming a sponsor. As fate would have it i've already been in talks with AutoGuide about combined pricing for this forum and CF since I am on there.
In short - I feel bad that I haven't been able to help Matt. He is going through the valves and adjusting them again and in the process i've requested he send back the injectors so I can have them tested on the flow bench and in the Bosch test stand itself at II. I know lots of guys don't like them, however they have treated me and all my customers great. I like that i can personally walk in a CP3, a set of injectors, etc and WATCH them be tested and get the printout right from the Bosch test stand on each injector, if it's balanced, it's return rate, etc.... and have them tested however i want at whatever pressures I want all the way up to 28k... Not trying to change any minds here, just saying that they've had their growing pains like many places and I feel confident if it's an injector issue we're going to find it - or rule it out since he has them out anyways. Being able to watch it tested also means there's not much chance of getting BS'd too - another reason I like the setup.
I try my best for all my customers, regardless of who's parts or what setup they're using - but i've had a couple trucks that just kick my backside in the end and I can't solve the problems for them. I hate when it happens. I didn't take offense to anything in the thread - there has been lots of great discussion so far in the thread (ideas and such) - and like I said in my original post. I make mistakes too. One way or the other, I hope we can get his truck to where it should be and close this thread on a positive note.
That being said, anyone that has additional ideas or input for him or for me - feel free to fire away! I'm continually learning and trying to improve.... so please keep any ideas coming!
zfuller123 is offline   Reply With Quote
Old 01-04-2013, 11:00 AM   eBay Motors  #34 (permalink)
bluessmax's Avatar
That's why you and I get along... Very humble attitude. Keep up the great work man!
-Kory
11' Denali LML<----Not stock and no box tuna :-)
06 SC/LB LBZ
10.87@128.5
Fully Built- Danville 72VVT, S482, Exergy 60%
**CALVIN'S TRANS**
Efilive by Power Performance (Latuning)
Need/Want our Efilive tuning?
http://www.syntheticmotorsports.com/
How about a free Efilive tutorial?
http://www.latuning.com/wordpress/?page_id=182 (Passcode 7777)
bluessmax is offline   Reply With Quote
Old 01-05-2013, 03:00 AM   eBay Motors  #35 (permalink)
Zach, you are definitely going about it the right way IMHO. When you have an issue like this where it doesn't respond as you would expect then I've always found it helpful to methodically recheck all the systems. I definitely think it was helpful to bench check all the injectors (doesn't matter what brand you're using, test results will tell you one way or another) and then to double check valve clearances. An overall compression test would also be helpful to know the mechanical systems are working as they should be. It would be nice to also have some verification that the timing gear on the cam was installed and lined up properly. Beyond that it would be good to pressurize the intake and double check it all for any possible boost leaks (I would use 5psi more than the max pressure that turbo will see.......it would be good to use the KENT-MOORE J-46091-15 adapter for the test). Next I would have a look at both the baro and MAP sensors to check they aren't plugged/damaged and that the signal they are sending is correct. Finally I would sweep the turbo vanes to makes sure you're getting full movement (0-100%). If all these check out then it's time to start digging a bit deeper.
Hope this helps.
MTL_Dmax is offline   Reply With Quote
Old 01-16-2013, 04:46 PM   eBay Motors  #36 (permalink)
Anyone mention a possible boost leak yet?
DuramaxNoKaOi is offline   Reply With Quote
Old 01-16-2013, 07:06 PM   eBay Motors  #37 (permalink)
Oh yes.... he went through ALOT of stuff testing that.... things were good there...
Injectors appear to be the culprit - still waiting for a final verdict tomorrow - but looks like there's a problem with them when they were tested in the Bosch machine - but i'm not going to pretend to be an injector expert - I only know they weren't happy with the results and are tearing each one down to go through them.
The tips ended up being 45% tips as well. Not a huge difference, but not exactly what the tuning was aimed at so.... a few compounding problems but I think this will be the ticket to getting his truck right.
We will definitely post up the results once everything is back together and running.
Old 01-16-2013, 07:50 PM   eBay Motors  #38 (permalink)
boostnlb7's Avatar
good luck with it, hope to see it get straightened out !!!
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is online now   Reply With Quote
Old 01-17-2013, 03:39 AM   eBay Motors  #39 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
Originally Posted by mparker View Post
I'm having trouble trying to get my EGTs under control. They are at 1000 just driving drown the road. When i try to go up hill they are 1400+. I've been working with a tunner and my data logs. My balance rates are within spec. Timming and boost look fine.This all started when I installed a different engine. With some mods.
ANY IDEAS would be great. Im stumped so's my tunner
THANKS Matt
MODS 42%cp3,30% injectors, fuel rail plug and ported fitting,Dannsville 68mm stage2, 3"down pipe,5"ex,afe intake,pcv reroute,lb7 pistons cut and coated, Efi live dsp5,egr blocked, Fass150
Originally Posted by 01 D_Max View Post
Yes, too much boost for sure. And I would think you were told the wrong size of the injectors... If He's tuning for what you were told, and they are bigger your going to dump more fuel than you think. Raising EGT's.
Wrong size of injectors? They came from industrial and said 30% over on the boxes. Im not having much black smoke now. What more info would u like?
Hmmm... Guess I do have an idea of what I'm talking about!
-Aaron-
2001 GMC Sierra 2500HD, Limited Edition, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires,
MANY More extras inside...
01 D_Max is offline   Reply With Quote
Old 01-17-2013, 04:49 AM   eBay Motors  #40 (permalink)
Needs a S.A.S.
WVRigRat05's Avatar
I'm running 20 over II's on mine they only have 20k on them and ones bad I think, my egt's are shit as well and getting a slight loss in rail pressure too and loud knock under load. Anyone know if they warranty their shit?
Reger
Black on Black 05' Silverado 2500 HD 4X4 CC/SB, LBY7, LT. 8580 lbs
Built motor/Trans and tuned by Blackout Performance
Engine- LB7 block, keyed crank and cam, LBZ rods, cut LB7 pistons, ATI damper, MA pushrods, MA motor mounts, LML man., new guts in heads, blocked, re-routed, Bills custom intake
Trans- PPE stage V Suncoast 1057 converter
Exhaust- 3" D.E. dp, 4" MBRP, 5" RBP tip
Suspension- Leveling kit buried, 3 rear springs added, Moto Metal 956's, 35's
Steering- Cognito braces, Cognito sway bar links, P/S cooler, straight centerlink, Rare parts tie rods
Interior- Wilson cell amp, Galaxy 73V, Boomer 400 linear, scanner, bluetooth
2011 30' Puma KDBSS
WVRigRat05 is offline   Reply With Quote
