HIGH EGT's lbz - Chevy and GMC Duramax Diesel Forum
Old 12-21-2012, 07:52 PM   eBay Motors  #1 (permalink)
mparker's Avatar
HIGH EGT's lbz
I'm having trouble trying to get my EGTs under control. They are at 1000 just driving drown the road. When i try to go up hill they are 1400+. I've been working with a tunner and my data logs. My balance rates are within spec. Timming and boost look fine.This all started when I installed a different engine. With some mods.
ANY IDEAS would be great. Im stumped so's my tunner
THANKS Matt
MODS 42%cp3,30% injectors, fuel rail plug and ported fitting,Dannsville 68mm stage2, 3"down pipe,5"ex,afe intake,pcv reroute,lb7 pistons cut and coated, Efi live dsp5,egr blocked, Fass150
mparker is offline   Reply With Quote
Old 12-21-2012, 07:59 PM   eBay Motors  #2 (permalink)
boostnlb7's Avatar
thats pretty high, at 60mph im only running about 600 maybe a lil more.. what are u using for a pyro gauge/
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 12-21-2012, 08:04 PM   eBay Motors  #3 (permalink)
mparker's Avatar
Its an autometer gauge with my old prob from my old bullydog i had before. Im going to try another prob tomorrow
Old 12-21-2012, 08:15 PM   eBay Motors  #4 (permalink)
boostnlb7's Avatar
id try that and see..
Old 12-24-2012, 10:28 PM   eBay Motors  #5 (permalink)
mparker's Avatar
Well I tried a new prob. no luck. Still having high egt's.
Any other things i should try?
Old 12-24-2012, 10:39 PM   eBay Motors  #6 (permalink)
Thebiggids's Avatar
Probably tuner relatedddd
Gideon
01 LB7 EC/SB Ally 4x4 shop ornament
DD: 1990 4runner completely stock 4x4 3.slow
Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel
Thebiggids is offline   Reply With Quote
Old 12-24-2012, 11:36 PM   eBay Motors  #7 (permalink)
mparker's Avatar
HIGH EGT's lbzhttp://www.mysmiley.net/imgs/smile/sign/sign0085.gif
I'm having a problem with egt's being high. There at 1000 just cruising at 60mph, boost is at 9lb. When I go up a hill they go 1400+. I've done data logs and all looks good even balance rates. Just HIGH egt's
This all started when I installed another engine in my truck. Its got some mods. 42%cp3, 30%injectors,dannsville 68mm stage 2. My tuner and I are stumped.
ANYONE with ideas, or what else should we check
I did try another egt prob and it the same. so prob is good.
Old 12-25-2012, 04:32 AM   eBay Motors  #8 (permalink)
Creepy
TheStepChild's Avatar
Who did your tuning, some guy or a reputable tuner?
'07 LBZ
'12 Express Van
TheStepChild is online now   Reply With Quote
Old 12-25-2012, 06:04 AM   eBay Motors  #9 (permalink)
Thebiggids's Avatar
Try someone elses tuning. 9 lbs and 1000* seems high. Id aay post pw and timimg but thats like giving away the tune.
Gideon
Old 12-25-2012, 06:18 AM   eBay Motors  #10 (permalink)
KB3MMX's Avatar
9psi cruising is way too much boost unless your dragging a trailer. Vane position sounds to be way too tight.
How about some more info...?
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
