efi live wont change with edge cts - Chevy and GMC Duramax Diesel Forum
Old 12-25-2012, 11:31 AM   eBay Motors  #1 (permalink)
thacker's Avatar
I have efi tunes by rob , hooked my Edge frs UI this morning and cannot get thé tunes to change im stock in position 1 on thé monitor, Amy help would be great
thacker is offline   Reply With Quote
Old 12-25-2012, 11:58 AM   eBay Motors  #2 (permalink)
Koolaid's Avatar
Did you go under options on the cts and change efi live from off to on?
2001 Chevy 2500HD
Efi Live v2
305/55R20 Nitto Trail Grapplers
BMF Rims
Leveling kit
5" straight pipe
6" tip
20% Tint
Koolaid is offline   Reply With Quote
Old 12-25-2012, 12:23 PM   eBay Motors  #3 (permalink)
thacker's Avatar
Yup
Old 12-25-2012, 12:23 PM   eBay Motors  #4 (permalink)
Koolaid's Avatar
Did you full flash it?
2001 Chevy 2500HD
Efi Live v2
BMF Rims
Leveling kit
5" straight pipe
6" tip
20% Tint
Old 12-25-2012, 12:25 PM   eBay Motors  #5 (permalink)
6dot6's Avatar
what year truck?
- 2010 GMC sierra dually SLT CC -
sdp twins,60 overs, efi by rob, trac bars
built trans/ suncoast 1058 converter
djm 3/5, sleeves and braces, 5inch straight pipe
cts insight, ad2 165, 1pc shaft, reroute
airbags, bt lockbox
thanks to: Bigdipper, ATP, BT Dieselworks, Blackout Performance
time to beat: 12.60 @ 108
6dot6 is offline   Reply With Quote
Old 12-25-2012, 12:29 PM   eBay Motors  #6 (permalink)
thacker's Avatar
05 i think
Old 12-25-2012, 12:40 PM   eBay Motors  #7 (permalink)
EFI-Live Tuner
Moonshine's Avatar
The last three I did with an Edge CTS would not work, they switched fine on the bench harness with the V2, customer received the programmed ecm and it would not switch.
Better off with a harwired switch !!
Tony Martino- Ridge Runner Diesel Performance, LLC
V2 - Autocal - Pre-Tuned ECM's available......... www.ridgerunnerdieselperformance.com
RRDP/COTN - EFI-Live Sales
Custom ECM and TCM Tuning for 2001-2010 LB7, LLY, LBZ and LMM trucks, accessories and bundles available thru Creatures of the Night Performance - Henry Webb
Moonshine is offline   Reply With Quote
Old 12-25-2012, 01:05 PM   eBay Motors  #8 (permalink)
thacker's Avatar
I hope not Thats thé only reason i bought thé edge
Old 12-25-2012, 02:46 PM   eBay Motors  #9 (permalink)
SST 1953's Avatar
Better verify the year, and be sure it's not an LBZ.
2007 CCSB LBZ.
EFI live DSP 5 by Rob @ ATP
EGR blocked, PVC reroute
AirDog II 165
TransGo Jr/pump rub mod
Firestone bags
4" MBRP
Edge Insite CTS w/ backcam
Cognito W/Bilsteins
69 Camaro S/ST-S/Gas
SST 1953 is offline   Reply With Quote
Old 12-25-2012, 02:49 PM   eBay Motors  #10 (permalink)
thacker's Avatar
Its def à o5 i put thé lbz intake on it , im about to try to reflash it
