Fuel mileage problems with EFI Live - Chevy and GMC Duramax Diesel Forum
post #1 of 17 (permalink) Old 01-24-2013, 09:01 AM Thread Starter
wolfie03LB7's Avatar
Hi guys 2003 chevy 2500hd EC SB. My problem is that since I got my efi live my truck wont get over 16 mpg hand calculated. Its not due to my driving habits and i only use the truck to go 20-30 miles a day. I have tried mulitipule times on each tune including optimized stock and it gets 16 miles to the gallon. I had the injectors replace 10k miles ago and i run amsoil in the motor. Could it be a bad tune? could it be a failing injector already?
Thanks guys I appricate it, Dustin
wolfie03LB7 is offline
post #2 of 17 (permalink) Old 01-24-2013, 05:02 PM
Hotdogstand's Avatar
Do you own a V2? Try a power balance test or check your injector balance rates. New injectors should have lasted more than 10k miles, but improper installation or a leaking cup could always be a problem, not to say that manufacturer defects are unheard of.
Regarding your tune, reduce the desired boost as cruising speeds (2000-2500 RPM) on your maps. It takes fuel to make boost. Even on my hottest tune, I barely lift the needle on the boost gauge once I get on the interstate, and I get about 20 highway.
If you have some money you aren't using, get an Air Dog or a fass (fuel lift pump) and fill out your sig so we know what you're working with.
Good luck!
2003 Chevy 2500HD D/A ECSB 221K (Sold)
EFI Live DSP5 (thank you to Dustin and Idaho Rob @ATP Trucks), batmowheel & BD wastegate (thanks to MrManners @ Synthetic Motorsports), Kryptonite tie-rods, MBRP downpipe and 4" straight pipe, 33" BF Goodrich A/T KOs on H2s
2007 LMM/Alli CCSB 4x4 (Sold)
EFI Live and downpipe/5"
(needs love)
2007 Grand Prix GTP (needs headers and s#!*)
Hotdogstand is offline
post #3 of 17 (permalink) Old 01-24-2013, 05:11 PM
D_Wags_DirtyLB7's Avatar
what kind of milage are you getting on a longer run? cause 20-30 miles a day is like city driving so your mileage aint going to be real high anyway.
Dustin - 2014 Silverado 1500 Z71 5.3
SOLD-03 GMC Seirra 2500HD CCSB LB7
K&N intake, 20" Black Moto Metal 961's, 285/55R20 Nitto Terra Grapplers, Kicker speakers, Straight Pipe,PPE Boost Valve
30% Exergy Sticks, EFI LIVE,Rare Parts G2 tie rods
D_Wags_DirtyLB7 is offline
post #4 of 17 (permalink) Old 01-25-2013, 11:11 AM Thread Starter
No i do not have the v2 i went with the pre tuned ecm from ATP trucks. I do have a diesel shop within driving distance to get my injectors balance rates checked.... Longer trips I also see right at 16 miles to the gallon longer being 250 miles highway and interstate. and yes your right 16 isn't necessarily horrible in town but I just expected and herd from others that were getting a little better. Anyway thanks for the replys i appricate it
Dustin
2004 Chevy 2500 HD ext cab LB7. EFI by ATP. MA700 trans. T-case brace and pump rub fix. Cobalt guages&CTS. ADII 165. Cognito suspension. PPE boost valve. Pro Fab turbo horn. K&N intake. Injectors 1/1/2015. 5" straight pipe. Traction bars.
Previous Trucks.
2006 Chevy 2500HD Crew cab short bed.
4 inch MBRP. Edge Insight CTS. EFI Live by ATP.Alligator Transmission lines.
2003 Chevy 2500HD. EFI Live DSP5 by Idaho Rob.
Air Dog II 165. Alligator turbo horn. PPE boost valve. 4 inch straight pipe.
post #5 of 17 (permalink) Old 01-25-2013, 11:17 AM
Sfarl3y's Avatar
I am having the same problem on my 03 with the ppe I was getting 16 city and 20 hwy since I've gotten efi live my mileage is 13.5 city and 17 hwy if I'm lucky
03' LB7
Sfarl3y is offline
post #6 of 17 (permalink) Old 01-25-2013, 11:20 AM Thread Starter
who did your tuning and what size tires are you turning?
I was wondering if an intake would help me out, i really doubted it would Ithink they are mainly for looks but i see you have the s&b
Previous Trucks.
post #7 of 17 (permalink) Old 01-25-2013, 12:12 PM
Sfarl3y's Avatar
My tuning is done by Starlite diesel I am pretty sure he does a lot of tuning for industrial injection as far as tire size 305/55/R20
03' LB7
Sfarl3y is offline
post #8 of 17 (permalink) Old 01-25-2013, 12:49 PM
ATPTRUCKS
sickdiesel's Avatar
Remember that winter time typically means worse mileage. A) due to winter blend fuel. B) harder for the truck to warm up. C) if you only drive short distances like you said the truck doesnt get up to temp and a cold diesel isnt very efficent.
thanks
dustin
2017 GMC Denali CC/LB L5P
06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5 SOLD
07 Chevy lbz 4x4 Caged and built 10.42@134 SOLD
Special thanks to: Mike L, Gtrippin, IdahoRob, Dmaxstore, HSP, ISSPRO, Yukon, Airdog
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
sickdiesel is offline
post #9 of 17 (permalink) Old 01-25-2013, 01:00 PM Thread Starter
Thanks for replying! I do always plug it in well under 30 degrees or so and i also allow it to warm up for 5-10 minutes but still your right do you think that it would be worth it to have the injector rates tested? no white or blue smoke no fuel in oil but i have a warranty on them about to run out? thanks!
Previous Trucks.
post #10 of 17 (permalink) Old 01-25-2013, 02:17 PM
ATPTRUCKS
sickdiesel's Avatar
i dont think having the injectors tested is necessary.
Remember too if you let it warm up for 10 minutes everyday that is gonna add up quick.
IMO 16 is good for winter.
