Des, you wont be able to add the High Idle to the truck that was factory option. The elevated Idle on my truck worked with the 083 os. I can send you a copy of that os if you wanna try.
So how does GM expect to keep a diesel at or even close to operating temp when its -40 out? Mike they got rid of the elevated idle on my truck sometime last may because of tranny failure and i dont want to by a tranny just yet since my warrenty is most likly void
Might just take it to the dealer and see what they say
isnt the fast idle just in the programming?
I dont really want to go to the dealer cause i might just leave the truck there and go buy a f..d
My 2009 3500 still has the elevated idle. That's odd yours did not come with it as an option unless the truck might have been destined to go south? The vmac guys are good and I am sure if you give a call to them in Nanaimo someone could help you.
Good luck!
Has that guy messed with it yet ? I have a buddy that just Bought a new 09 LMM (have know idea on OS) but is intrested in high idle . Does yours still work after the OS change ?
Efi live cant do nothing with the high or elevated idle that i know of, it is programmed in the BCM from what i found out. It has to be factory eqquipped for the high idle to work.
Elevated idle is controlled in the DIC, high idle is by the cruise controls with the e-brake on if so equiped.
carry a brick around with you... thats gay that your truck did not come with it from the factory! i bet the dealer can fix that for you. just like they can fix the TPMS but say they can't.
__________________ Vehicle 2008 Chevy Crew Cab Short Bed Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck Drivetrain LMM Duramax, Allsion 1000 Transmssion Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Mike,
Would the LBZ high idle switch work on the LMMs also?
I'm wiring the high idle switch into mine. Sometimes I want to warm it up fast when its not below 32º. I want to be able to use it for the A/C also.
__________________ 06 Chevy LBZ/Allison 4x4 EFILive, SC IV, stock turbo, lowered, 94,000 miles and counting 12.60 @ 105.41 mph PicturesVideos
The First Law of Thermodynamics states that energy can neither be created nor destroyed... unless it meets Chuck Norris.
