Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > EFI Live
Old 11-04-2009, 07:10 AM   eBay Motors   #11 (permalink)
Texas Rocket
I would also like to know. I haul equipment everyday. Back hoes, construction equiment. I live in H town pretty flat. I would like to get a tow tune.
07 Classic, white duelly crewcab, 4by4, airbags 4"mbrp turbo back, Stealth2 at 70 horse, intake mod, debadged, painted bowtie white on grill.
Texas Rocket is offline   Reply With Quote
Old 11-04-2009, 07:56 AM   eBay Motors   #12 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
IMO, just like any other tune, just less of everything. my tow tune only has 210000Us pulse width and 22* of timing. stock has about 1700 pluse width and 18* of timing.
my tow tune is my favorite daily drive tune because it runs a little more egt's than stock, has 350rwhp, and gets great mileage for such a small tune.
my tow tune actually has less boost at 65 than my stock tune does, but maxes out at 26psi while stock is around 24psi. Also, you can lower your desired boost levels at cruising speed to help in MPG's. now, at 65, i cruise at 2psi instead of 6psi with the same tune.
Old 11-04-2009, 03:46 PM   eBay Motors   #13 (permalink)
climber
climber's Avatar
And heres one for the tuners too. My buddy has a powerstoke with a bully dog. The manual for it said do not tow on 100 extra hp. 3000lbs or less on 75hp, 6000lbs or less on 50hp (not sure if extact weights). Whats the deal with less hp for a heavier trailer. My tune is around 400hp, and i tow about 4500-5000lbs with that on. Is that bad?
Dan
06 2500HD GMC LBZ, ECSB, 285 Cooper ST on 16" American Racing Wheels, Diamond Eye 4" into 6" Bullhaulers, Glow Shift A-Pillar Guages, Tuned with EFI Live.
climber is offline   Reply With Quote
Old 11-04-2009, 04:04 PM   eBay Motors   #14 (permalink)
seth999
Duramax Forum Moderator
seth999's Avatar
yeah your pistons are prolly hating life...and with a stock tranny...the stock HP is ~300 at the rear wheels so 400hp is over 100hp over stock thats not even safe without ANY load...the reason it says this is because the more fuel you throw at it the higher the egt's will be then add weight and you start getting too high egt's
DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
seth999 is online now   Reply With Quote
Old 11-04-2009, 08:26 PM   eBay Motors   #15 (permalink)
climber
climber's Avatar
Ya thats sounds about right... LOL But from what I can see with that tune and the stock theres no difference in temps. But I wont really be able to tell until I finish my gauges.
Old 11-05-2009, 02:55 PM   eBay Motors   #16 (permalink)
Buck
Buck's Avatar
bump...anyone esle wanna chime in?
Vehicle 2008 Chevy Crew Cab Short Bed
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline   Reply With Quote
Old 11-05-2009, 03:25 PM   eBay Motors   #17 (permalink)
lbz125
i run efi live, my buddy tumes my truck, i run around 55hp tune when i tow my bobcat or other good size loads, its also a great tune for highway driving imo i get around 23mpg on the highway
06 lbz cc/sb
efi live
4" straight piped
285 BFGs on stock wheels
have gauges just got to put them in
lbz125 is offline   Reply With Quote
Old 11-05-2009, 08:19 PM   eBay Motors   #18 (permalink)
1GCHK23D
I'm thinking a tow tune almost needs to be custom made for everyone. You need gauges if you've done anything to your truck. I pulled a empty 5x7 single axle trailer and egt's went from 5-7 hundred to 8-1000.
1GCHK23D is offline   Reply With Quote
Old 11-06-2009, 05:30 PM   eBay Motors   #19 (permalink)
gorgon182001
efi live is not a good system my opinion i have many buddies that run it and unless the designers of duramax gives you a tune dont trust some guy that thinks he knows what he is doing
gorgon182001 is offline   Reply With Quote
Old 11-06-2009, 05:45 PM   eBay Motors   #20 (permalink)
delong_1
truck for sale
delong_1's Avatar
interesting opinion, there are a decent amount of people running efi live and the only time that it becomes and issue is when major changes are made by inexperienced people or pushing the limits of stock parts.
Nate
2 turbos, built trans, and some tuning.
