2.5L Jeep YJ - Water in Oil - Chevy and GMC Duramax Diesel Forum
Gas Burners Discussion of anything Gas powered.
post #1 of 8 (permalink) Old 10-13-2012, 03:42 AM Thread Starter
FCM
My cousin brought me his YJ with a 2.5L saying that it kept overheating. Long story short, all the water was leaking into the oil pan.
I am being told that the engine had been "reworked" prior to it being given to me to fix. Part of the work was that the block and head were magnafluxed and new gaskets were put on the head. Supposably the head bolts weren't torqued down right and that was the reason he decided to bring it to me. I went ahead and replaced the head gasket and torqued the head bolts as per the Haynes manual.
I still have water in the oil. Not just a little, but a ten minute test drive nets me a half empty radiator. If the head and block passed the magnaflux test and a new head gasket was installed and torqued correctly, what other possibilities are there?
Update: I just disassembled the entire engine so I could really inspect it and as of yet cannot see anything. I still need to clean all the milk off of everything.
2007 Chevrolet Silverado Classic 2500HD - EFI Live, AirDog II, Nicktane Adapter, Resonator Plug
FCM is offline
post #2 of 8 (permalink) Old 10-14-2012, 06:29 AM Thread Starter
FCM
bump...
FCM is offline
post #3 of 8 (permalink) Old 10-14-2012, 06:58 AM
rd05lly's Avatar
I do not keep up on Jeeps but how many places can they mix. Head, Block, is there an oil cooler? Was it put back together with reused head bolts?
05 CCSB EFI Live by PPEI
2011 Chevy Tahoe
04 Olds Alero DD
76 Dodge Charger SE
https://www.syntheticmotorsports.com
rd05lly is offline
post #4 of 8 (permalink) Old 10-14-2012, 07:25 AM
MudDoc's Avatar
was the head and block decked?
If not then there might be your problem, overheating leads to warpage, warpage leads to leaks around gaskets/seals ect.
Since it is disassembled I would have the block and head checked for how "true" it is. If it aint flat get it decked/milled
2013 Huffy Ultimate Spiderman bicycle
baseball card in back wheel mod
TRAINING WHEELS OFF!!! 09-22-13
Streamer handle mod
Saving for front basket
MudDoc is offline
post #5 of 8 (permalink) Old 10-14-2012, 04:07 PM Thread Starter
FCM
Good idea. I'll check how true they are and see what happens.
FCM is offline
post #6 of 8 (permalink) Old 10-14-2012, 04:17 PM
6dot6's Avatar
do the jeeps have a radiator that also has oil and or tranny coolers on the side?
2014 ram 3500 dually staying stock
6dot6 is offline
post #7 of 8 (permalink) Old 10-15-2012, 07:36 AM Thread Starter
FCM
Nope, no trans cooler or anything on this Jeep.
FCM is offline
post #8 of 8 (permalink) Old 10-17-2012, 11:40 AM
MudDoc's Avatar
interested in the update here
Streamer handle mod
MudDoc is offline
